Sorry for the delay gents.
The 202c has a truely superior mid/hi balance/timbre that really can be best described as beautiful, i have often felt that this is where THX speakers fall, but then under THX post processing the top is somewhat subdued, certainly if i had any complaint with the 23C (of which i think is a great value for money center and i wholly subscribe to the "thinking" behind THX) it was that it had a slightly "boxy" presence with some mid frequencies. When down mixing 5.1 dvd and 2 channel stereo to mono (on the Tag av32r this is down mixed to the center channel only - very useful) and placing the 200c on top of the 23c which in turn sat on the 202c and fed with a 250w Denon mono-block (poa6600, certainly a reasonable affair, 1.5va transformer, 50,000 uf cap's etc etc Big as the avc1se etc) it was an absolutely fair comparison, the 202c made the 23c literally sound as if it was facing the opposite direction (even my wife made the rarest of comments to the point of "god your speaker (23c) sounds awful, i hasten to add the 23c is not at all awful but the 202c was that much better) and it clearly had more "presence" and space than the 200c. The lower frequencies (80hz and above) were simply better defined, with far better integration wth the other drive units and timing to match. Probably the only bad thing i can say about it so far is that believe products even like the mighty a1se, a11sr would not do this justice, on my reasonable set-up it has had a remarkable effect in "center-pinning" the whole thing together, even the missmatch in timbre's (some what eleviated by THX) to my ears becomes secondary to just how good this center is.
Whislt i realise that there is not much real info here, suffice it to say that the beautifully "airy" (the hyper tweeter with a crosssover frequency of 15khz! REALLY does work even with THX which was my only reservation before buying/purchasing) tops, the seemingly "out of the speaker enclosure" mids and the tight, dry lows are so much better than the other two speakers listed that (gush gush) that for me the cost was almost secondary.
Right up there with the joy's that are the Tag av32r and Kef 34ds.
Now if only i had 3 poa6600's to tri-amp it.
Steve.
