New iPod nano
Discussion in 'Headphones, Earphones & Portable Music' started by grahamricho, Sep 11, 2007.
Tags:
  1. grahamricho
    grahamricho
    Oct 29, 2001
    1,124
    48
    York
    +47
    Just a short note to say I got the new iPod nano delivered from Apple and its stunning, makes the old iPod nano seem like its from the ark !
  2. marcstang
    marcstang
    May 10, 2005
    1,546
    Not so sunny Cheshire
    +140
    Picked an 8gig one up from Singapore earlier this week to replace my broken 4g 20gig. I'm loving it. User interface and Video quality is also brilliant.
  3. gordon115
    gordon115
    Oct 24, 2005
    280
    +12
    Do ipod nanos come with a charger or do you have to plug it into the computer everytime it wants charging?
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,222
    83
    Over the Hill & Far Away
    +140
    Have you been able to try out video on it yet ? Is it usable ?
    Also hows the gui performance.. do you get any lag when using the cover flow feature for example ?
    Ta
  5. grahamricho
    grahamricho
    Oct 29, 2001
    1,124
    48
    York
    +47
    it comes without a charger just the usb lead and some headphones.
    I put some videos on it and the image is very crisp and easy to do, i put my holiday video on what i shot with a camcorder and some music videos and they look great.
    I had a old nano and this one is 10x better, its interface is better, the 3 games on it look great, the music quiz is also a lot better and it has a movie and tv quiz built in.the music quiz you can bet on the answer and its set as if its a quiz show . i thought for the money its stunning !
  6. marcstang
    marcstang
    May 10, 2005
    1,546
    +140
    Converted a few movies and TV eps and put them on it. Video playback is smooth. I originally compared the playback between the nano and the classic in the store prior to purchasing it and couldn't see any difference between the two. There is no lag on the coverflow.
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I'm considering buying a 2G Nano at an awesome price or a 3G Nano... must decide fast...:rolleyes:
  8. TigerBytes
    TigerBytes
    Jan 5, 2006
    572
    Bristol
    +22
    Can I just confirm something with all you Ipod users, just bought a 3rd gen 8gb Nano, but Comet stated on the description slip, that this 3rd Gen Nano was drop and Drag technology, would I be right to assume that It's not the case, and you still have to use Itunes.
  9. eddidaz
    eddidaz
    May 23, 2005
    345
    Manchester
    +6
    I'm pretty sure none of the iPods have ever officially used drag and drop. Always had to use iTunes as far as I know.
  10. BananaTiger
    BananaTiger
    Oct 25, 2005
    1,194
    +124
    I've just got my first iPod which is the 3rd generation nano. I'm pretty happy with it so far, but one niggle is the sensitivity of the touch wheel. Maybe I have to get used to it, but is there any way I can change this? There doesn't seem to be anything within the nano menu system to do this.
  11. L4dva
    L4dva
    Oct 26, 2007
    167
    +9
    hey I have a new nano aswel, its fab!
    not sure wat comet ment by drag and drop, but I know that itunes allows you to drag and drop music straight to your ipod. you can drag and drop from your itunes library, AND you can drag and drop folders or files from my computer straight to ur ipod via itunes. you have to drag the files/folders to your ipod under the devices in itunes, the music you draged and droped will go straight to ur ipod and not on ur itunes library. either way you have to use itunes.
