New iPod Mini Won't Work!
Discussion in 'Headphones, Earphones & Portable Music' started by eviljohn2, Jul 19, 2005.
Tags:
  1. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Please Help!
    I've spent the last 2 nights at my mates house trying to make his iPod mini work to no avail.
    I've managed to reach a stage where if I connect it, it will charge but Windows XP SP2 doesn't recognise the device so it won't work with any software - it's not even recognised in Explorer as an additional drive.
    Any ideas on what to try next?
  2. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    Have you tried reseting it ? Have a look in the iPod hints and tips in the FAQ thread for a couple of ideas.
    It's also important not to format the device from windows as there are hidden folders on an iPod and they areonly created through the iPod software that comes with the player.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Tried resetting it, tried reinstalling the software. I can't format the device as the computer won't recognise it - I've found these symptoms on a number of support sites but not one has the solution. :(
  4. mick's cat
    mick's cat
    Assuming the iPod's on a USB port, try connecting your iPod to a computer with a FireWire port. I've seen a few reports that doing so can solve the situation (never confirmed it myself however, as I've already got FireWire so never bothered to use USB).
    If you're close to an Apple dealer, then you might try taking it in there for them to check for you. They're normally pretty helpful.
    Is the iPod still under warranty?
  5. JayCee
    JayCee
    Jan 20, 2004
    22,401
    Lanarkshire
    +2,346
    Have you installed the iPod updater software, then connecting it?
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    To answer the questions:
    The iPod is only 2 weeks old so should still be under warranty.
    They don't have a firewire port on the computer - I had to install a USB2 card (which is working fine) as it is.
    They don't have broadband so I havn't been able to try the iPod updater software.
  7. mick's cat
    mick's cat
    Hmm, could still be the USB2 card, as the iPod may not be playing with it. You can check Apple's known list of cards that work:
    http://docs.info.apple.com/article.html?artnum=93405
    but just because a card's not on the list doean't mean it shouldn't work - it just hasn't been tried. I think the best test is if you can check the iPod on another computer to confirm whether it's the iPod or not.
  8. JayCee
    JayCee
    Jan 20, 2004
    22,401
    Lanarkshire
    +2,346
    I doubt very much the iPod is faulty.
    My daughter (despite me telling her I would do it) tried to install her new iPod herself, of course she did not do it properly and it then refused to recognise it when plugged in via USB.
    I told her to download the iPod updater, install it then plug in the iPod.........which was then recognized and proceeded to sync her iTunes.
    Get a friend to download the updater software, burn it to a CD, install it and all being well that should work.
