New installation
Discussion in 'Home Cinema Building DIY' started by torkus, Jun 26, 2003.
  1. torkus
    torkus
    Jul 2, 2002
    29
    Essex
    I will be having my through lounge decorated soon to accomodate a full home cinema (complete a/v set up).
    What I would like to know is does it matter if I have long cable runs (i.e. audio & video) from each piece of equipment?
    e.g Projector to DVD player.
    Will this produce a poorer quality picture? and also does the same apply to long cable runs?
    Should I place the A/V equipment as near as possible to the projector?
    Also, what's the best way to hide the cables?
    Any advice would be appreciated.
    :confused:
  2. AVcontroller
    AVcontroller
    :smashin:
    The distance you can run a video signal along a cable without any problems depends on the quality of the output of your equipment eg. DVD player and of course the cable itself.
    You will be fine running upto 20m off a reasonable DVD player.
    I recomend you use a cable made by Evolution, at work I have run this stuff at 50m with no problems.
    I recomend you run component, composite and SVHS to cover yourself for everything. Maybe also VGA data so you can connect your PC too. The whole lot from them should only work out at about £120.
    As far as hiding the cables, unless there is a loft above you and some stud hollow walls your going to have to make a few holes and get a plasterer in.
    Good luck.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,507
    7
    167
    Birmingham, UK
    +10,224
    SVHS is a type of video tape. You mean S-Video.
  4. AVcontroller
    AVcontroller
    Yep , I did mean S-Video not SVHS. I guess one sends luminace and chrominace while the other records it!
    I have tried sticking loads of SVHS tapes together in a long line to get a picture from a DVD player to a projector but the results were poor!
