New install help.
Discussion in 'Plasma TVs Forum' started by Baggy69, Aug 7, 2004.
  1. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Hi all, i have been given the job by my mate to connect up his new system that arrives next week but i could do with a bit of help choosing the best way to connect all of it up. What he is getting is - Pioneer 434HDE plasma, Pioneer NS-DV990 home cinema set, Panasonic DMR-E85HEBS DVD Burner, Panasonic NVFJ780 Video, Sky tv, Xbox and a PS2. With the DVD Burner able to record sky. Has anyone set a system up like this or know the best way of doing it???
    Thanks Ian.
  2. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Baggy,
    I am only 30 minutes from Birmingham centre. If you want some help give me a ring. details in sig below.
    Piers
    Home Cinema Engineering
    www.homecinemaengineering.com
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    Blimey, someone's bank manager is in for a shock, with all that gear coming at once :)
    I'm sure you'll have lots of fun helping him "test it out" when it's all hooked up ;)
  4. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Yes lucky him. It will be interesting to see what the pioneer speakers sound like as they look really good, a little less intrusive then my kef Q5's and Q1's.
    So do you think it will be as simple as -
    DVD-R to TV via Component via 3 way Component switch box (pic)
    DVD-R to DVD via optical (sound)
    DVD to TV via scart (sound and pic)
    SKY to VID to DVD-R to TV via Scarts (sound and pic)
    Xbox to TV via Xbox Component lead via 3 way Component switch box (pic)
    Xbox to DVD via Xbox Component lead (sound)
    PS2 to TV via PS2 Component lead via 3 way Component switch box (pic)
    PS2 to DVD via PS2 Component lead (sound)
    Cables in mind are -
    IXOS XPX04-200 (Xbox Cable) X 1
    IXOS XPP04-200 (PS2 Cable) X 1
    IXOS XHT611-075 Scarts X 4
    IXOS XHV804-100 Component Cable X 1
    IXOS XPP05-200 Optical Cable X 1
    Does all this sound ok?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Go VCR>SKY>DVD-R> Panel
  6. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Thanks hornydragon. What difference will this make ?
    Ian.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    VCR is composite only, this will allow for recording Sky in RGB on DVD-R and should prevent quality issue while watching sky. also connect second VCR scart to tuner if you have a spare scart.
  8. Baggy69
    Baggy69
    Mar 15, 2002
    189
    Birmingham, UK
    +3
    Thanks for that hornydragon, Roll on friday, thats when he wants me to do it. But my girlfriend babys due date is sat so i may not make it if baby is early. :eek:
  9. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Hi everyone,
    Hope you don't mind me poking my nose in on this one.
    I have the same equipment as Baggy69 with the exception that I have a Freeview Box instead of Sky (Hope to get Sky when the free to air offer emerges later this year as the Freeview digital signal is crap due to Trees). My panel is the Panny PWD6B.
    Could I set up my gear like hornydragon suggests
    VCR > Freeview > DVD-R > Panel
    At the moment I am not using my VCR as I didn't know where to connect it in.
    Would this allow me to transfer from VCR tape to DVD without changing connections?
    Hope Baggy69 and his friend get as much pleasure from the Plasma as I have.
    Good luck with the set up.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depending on FV box it should act as pass through when in standby. what FV box? and which DVD-R and Video? Will need 2 scarts tho.
  11. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Thanks for your reply hornydragon.
    Most of the equipment is "antique" i.e.
    Mitsubishi VCR (2 Scarts)
    Nokia On digital FV box (2 Scarts)
    Panasonic DMR E50 DVD REcorder (2 Scarts)
    Panasonic PWD6B Plasma (Scart Board)
    Sound via Sony AV amp
    The present set up is
    FV box > DVD-R > Plasma Panel
    Any comments gratefully received and faithfully applied.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    stick vcr onto FV vcr scart that way you can FV>VCR while DVD-R analogue for example. Bothrecording devices can record FV this way
  13. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Thanks a lot hornydragon. You seem to help an awful lot of people. I'm sure we are all most grateful for you taking time to share your valuable knowledge and expertise with us less technical folk.
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    thankyou mate not often people are so graceful. the plan it that you will stay around to dispense the info to other new members as you learn yourself.
