New in Japan - Sony STR-VZ555ES
Discussion in 'AV Receivers & Amplifiers' started by cybersoga, Jan 19, 2003.
Tags:
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Take a look at this, it appears to be almost the same as the STR-VA555ES, but it has a new remote, 7 channel amplified outputs (2 center rears), DTS 96/24 support, improved SNR, volume control goes up at 0.5 steps, and "Actualizes treble quality with the system which does not use the center speaker and the sub woofer the analog down mixed function which" which i dont quite understand.
    Link on Sony.jp
    [​IMG]
    [​IMG]
