New Ice install ideas for Peugeot 206 XSI
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by js, Jan 30, 2003.
  1. js
    js
    I am just about to go and pick up my new car and was wondering
    if anybody knew about speaker placement in the 206.
    It has a clarion CD headunit which is no doubt crap - I didn't
    particularly test it when at the showroom. I have removed my
    Kenwood CD headunit from my old car ready to install it into
    my Peugeot. The Kenwood is amp ready with 1 lineout I think.
    Ideally I'd like to put components in the front with a sub very
    well installed in the boot so it doesn't get in the way whatsover.
    The amp also needs to be out of the way.
    Anyone got any ideas on what size components I should fit and
    how much work is needed with regard to space in the door etc
    to fit them, also an idea of where to put the amp would be
    helpful.
    Cheers for any feedback.
  2. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Can't help with speakers but if your after a sub box that doesn't take up boot space look here
    Thinking about getting one for my Saxo
    Paul
  3. js
    js
    Excellent, thanks for that Paul. That looks like just what I need.
    The amp Boxz looks the biz as well.
    Back in the day I had a 12" Sub that took up the entire boot of my
    corsa with a vey large (and crap) Jensen amp bolted on the
    back of the seat, looked like a proper custom install :rotfl:
    Oh and some Infinity Reference 6*9s - still got these, no idea
    what to do with them though as they are bit old now, I also
    have the amp still and I might just leave that in the car when
    I drop it off tomorrow unless someone on here wants it.
