New HT Room - Is there a minimum size?
Discussion in 'Home Cinema Building DIY' started by p9ul, Aug 2, 2005.
  1. p9ul
    p9ul
    Jul 29, 2004
    8,702
    +767
    I'm currently doing plans for an extension to my own house (seeing as I've managed to finish all my mate's plans :suicide: ) and yes you guessed it - I'm gonna build in a HT room.
    The plan of the room at present is 2.8m x 2.8m which isn't huge but I reckon I can fit everything in without any problems - what I'd like to know is would I get any real benefits from making it slightly bigger? I'm a bit pushed for space but I could pinch an extra foot in each direction if I wanted to...
    thanks in advance.
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    acoustically, you dont want it square! A rectangle is best
  3. Zag
    Zag
    Jun 29, 2004
    907
    Poole
    +47
    My mate has his 4805 in a 10ft square room next to his garage. Its a bit on the small side but it does work. He has a 5ft screen which I find a bit small but apart from that it works well.
  4. Jamiroquai78
    Jamiroquai78
    My garage HC is 12 x 8 with a 96" screen perfect for what I need however IMHO any additional space you can squeeze on a smaller room is good space.
    If I had a 13 x 9 option I would definately have taken it :D
