New HS10 - widescreen modes toggle fault?
Discussion in 'Projectors, Screens & Video Processors' started by Marcus Wood, Feb 20, 2003.
  1. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    I got my new HS10 yesterday and I'm very pleased with it, but it does have one rather annoying problem. I'm not sure if this is common to all HS10s or if it's a fault with my unit.
    If I use the button on the remote to toggle through several widscreen modes, after I go through the first few modes, the projector just seems to hang up.
    The picture disappears for a second, and it stops responding to the remote. After a second the input status comes on at the top left hand corner. After a few seconds, it seems to sort itself out, and the picture comes back, and I can toggle through the modes again.
    This mostly happens when I'm in pillarboxed 4:3 mode and want to switch to anamorphic 16:9 mode (which involves toggling through most of the modes). It works fine if I only need to toggle through one or two modes to get to the one I want.
    Do they all do this?
  2. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Yep, I do. Perhaps there is another way to select widescreen modes that I don't know about...I haven't read the manual in full yet
    Conor
  3. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    Comer, thanks for your response, but I'm not sure what you meant. ;)
    Do you mean that yours has this problem too?
    You can change the aspect ratio in one of the menus, which would probably be easier than the toggle if you've got a Pronto or something like that. I haven't got one though - yet.
  4. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Yes, and it is quite annoying as is to toggle through the inputs
    Conor
  5. Lynchpin
    Lynchpin
    Yup, mine's the same, PITA.
    K.
  6. rooster
    rooster
    Mar 18, 2002
    224
    Edinburgh
    mines seems to work fine until full through mode, the last option and it usually takes a couple of secs, I thought it maybe takes more to convert to that mode so hence the delay. All the others are instantaneous
