New House - PreCabling
Discussion in 'Projectors, Screens & Video Processors' started by dnoguer, Aug 16, 2005.
  1. dnoguer
    dnoguer
    I'm building a new house and I would like to prepare one room for Ceiling mount Projector. The maximum distance between Projector and Screen can be 4 meter.
    I'm still not looking for projectors but I would like to precable it with the appropiate cables. I will mainly use it for DVD, TV and maybe laptop connection...
    I read about HDMI becoming the connection of the future, and I was thinking in HDMI and USB cable.
    Does HDMI cover all the applications?
    The distance for this cable will be between 8 to 10 meter.
    Can HDMI and USB reach this distances?
    Your comments are welcomed!
    Thanks for your help!
    Regards, David
  2. Comer
    Comer
    Sep 21, 2001
    1,385
    Ireland
    +85
    If it's possible, I would put in something like a wavan pipe with a couple of pull lines. You can pull cables though later and you should have a future proof system in place.
  3. mrm3
    mrm3
    Oct 29, 2004
    2,034
    48
    Cobham
    +95
    What do you want USB for?
    Yep to HDMI and need a power supply and component?
    PS If you are into techy stuff put ethernet cat 5e/6 cable around your house.
