New House Need Automation Help
warjam1945
Established Member
I am building a new house and i want to put in all the bells and whistles in home automation. The only problem i want to do it myself (with the help of a friendly spark). I haved looked at the nuvo range for sound but could someone please help me out and tell me the best equipment and the best place to get it. The house is in ireland and its around 5000sqft and i might also wire the garge up to.
Any help would be a great help.
warjam1945
Established Member
well i am looking to have sound in 6 - 8 rooms and TV in a least 5 - 6 rooms. Don't care about lighting really expect maybe in the cinema room. The little touches like heating and cctv controls i would add if the price was right. Seen a NuVo Grand Concerto for sale along with the keypads for 8 rooms all i need is plates for the tv,phone and data for each room.
hornydragon
CCTV can be done quite cost effectively Heating is more expensive and would require something more advanced than Nuvo. Nuvo grand concerto is good for music especially Ipod and radio.
warjam1945
Established Member
What about tv like sky to every room or several or the outputs from the cinema room like dvd/blu ray could they be streamed into every room cost effectively?
hornydragon
Depends on the quality your looking for but for upto 6 sources (Sky HD, DVD, Bluray, etc, etc, etc) then £3-4K for good quality video distribution kit
hornydragon
Depends on the electrician....If proficient at data cabling could wire for video distribution, the actual install and commisioning can be trickier depending on the kit. As for the hardware Intelix at the entry level (HDMI), Smart-e at higher level (mixed signal analogue video distribution) in between is AVatrix and Neopro
EDIT I have just had a sneak preview of video switcher 4x4 designed to be used with a multiroom system that should be under £2k this would make for a nice smaller system
hornydragon
it gives you 4 sources of video to 4 zones which can be part of a larger audio system which could be 6 sources to 8 zones (up to 4 of which could be video sources) and 4 zones could include video
warjam1945
Established Member
what money would that be? Is there a name or brand name of the item? Starting to get worried now about of these terms i don't know. Setting up a 5000sgft house and also a garage is starting to look a tall order.
CES 2023 Round Up: New TV Lineups for 2023 from LG, Samsung, Panasonic, Hisense & TCL
