New House cabling project
Discussion in 'Cables & Switches' started by ivanmurray, Nov 4, 2004.
  1. ivanmurray
    ivanmurray
    Jul 26, 2004
    13
    I am trying to source a number of items for an install in a new house.
    I need...
    Component video wall plates
    Component video cable
    Component video terminators RCA (male)
    Banana plug speaker wall plates
    Banana plug speaker cable terminators
    RJ45 wall plates, but with digital co-ax cable (instead of cat5)
    Speaker cable
    Its going to be a serious system with 6 rooms distributed audio (one outside)
    2 rooms sourround (one cinema projector room - HTPC)
    music studio
    etc.
    I am looking for good websites for cabling supplies that would deliver to UK and Ireland. I am also looking for a certain degree of quality.
    Any help appreciated greatly.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  3. ivanmurray
    ivanmurray
    Jul 26, 2004
    13
    thanks for advice, I tried, but did not find what I was looking for. Did stubble across....
    www.partsexpress.com
    looks pretty good, and they do deliver across the atlantic...
  4. cwoj
    cwoj
    Never seen a RJ45 Plate for digital co-ax cable. Can you tell me a little more about what your trying to do? I run a small networking company so might be able to help?
  5. ivanmurray
    ivanmurray
    Jul 26, 2004
    13
    just looking for bigger BW than cat5e for the home network. I was under the impression that I could run co-ax for my betwork instead, and assumed a RJ45 interconnect. What should I be looking for.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    RJ45 is specific to cat5/cat6 cable running a coax LAN is an Odd move whats wrong with Giga Bit Ethernet??? also for home cinema wall plates any CI dealer will be able to supply them in a range of finishes and fiitings. QED make them as doeas a US company whos name escapes me..... but are sold in the UK via RGB Distribution
  7. cwoj
    cwoj
    Cat5e would support gig bandwidth? & Then theres Cat 6. Co-ax was used on 10mb networks and cant support the levels of bandwidth your talking about. Its not just a simple case of installing good cables, its a question of what the hardware (switchs/routers) are doing. Some have better abilities than others. I would simply install Cat5e cable with RJ45 outlets. Make sure that the installers dont stand on, strech or kink the cable as this will affect performance (even though it will pass a cat5e test).
  8. farmnut
    farmnut
    How much component cable will you be looking for?
    I have a one-off shipment of Belden 7712A cable on route from the USA due any day now. I will have circa 110 feet of excess that I am looking to sell on at my cost plus UK postage or collection from my Cheshire home. Please read the Beekeeper notes on this cable.
    I will confirm cost once the duty and VAT elements have been settled and I know my total cost.
  9. farmnut
    farmnut
    The Belden cable arrived yesterday. I am able to sell on at my cost of £2 per foot plus cost of post & packing. Pickup from my Cheshire home is of course an option.
    Let me know if you are interested. Regards. Farmnut
