New House Build - What A/V cables?
Discussion in 'Home Cinema Building DIY' started by sal.wal, Apr 23, 2007.
  1. sal.wal
    sal.wal
    Sep 18, 2006
    5
    :lease: Hi Folks,
    About to start the First fix, hiding A/V the cables is not the problem.
    Having a false wall about 2" deep fitted against the main wall, where TV is going.
    Rear speakers & sub are going under the plaster.
    Its what cables I need to put behind the walls, that I don't know.
    I'm going to be running:
    HD Plasma/LCD 42" ish
    A/V receiver
    Freeview with Hard drive
    Upscaler DVD player
    5.1 speakers inc. sub
    and 2 Stereo speakers against main wall.
    I'm not concerned about running the Best cables available, I do have a budget.
    I just need to have an Idea what cables to run.
    Thanks.
  2. brethy
    brethy
    would it be possible to install a ducting system within the 2" gap so you can [fish] your cables through as you decide on a certain grade/make of cabling and with this you can alter them as and when needed?:thumbsup: :thumbsup:
  3. sal.wal
    sal.wal
    Sep 18, 2006
    5
    Thanks,
    As you say the 2" gap will leave room to add cables later.
  4. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    If you have a 2 inch gap to pull new stuff through (and some way to do it) then I'd go for just what you need for now, and spend on the quality of that.
    I had the same challenge, but with a bend to go around, so had to guess the cables for good - I put in dual component (one as a spare), S-video, centre speaker, dual phono pairs, aerial, and DVI-I ... and it still wasn't enough (but might help address your question - add HDMI instead of DVI now). No sooner was the wall 'shut' than HDMI came in instead of DVI! And a Wii sensor bar connection (no way to see that coming).
    I put in 20mm trunking so I could get more through in future, but you can't pull HDMI through that. So, in short, if you can leave the full 2 inch gap accessible then I would.
    Greg
