Chunkylover
Established Member
I'm in the planning stages of a new selfbuild, this will be a five bed detached home with four beds on the first floor and a fifth bedroom on the second floor.
One of the things I have been thinking a lot about and trying to educate myself on using this forum is the newtworking and automation I should put into the new build. I'm looking at having a rack located in the garage and networking throughout the house from this to each room.
My initial questions are,
1. Should i be running cat5 or cat6 cable to each room and on average how many cables??
2. Should I be running any other cables i.e. coax, speaker cable ??
2. Should I look at having the sky box / freeview boxes etc located in the rack and then transmitting the signal via the cat5/6 to each tv ?? Or is it better have the boxes sited local to the tv??
3. If I draw something out for cable routes is there anyone on here could help check it and advise if it looks ok?? If there's a small fee invlolved I'll pay it as I'm stuck when it comes to AV / networking infastructure.
4. I really fancied putting in a lutron lighting control system, but after being quoted silly figures at an exibition we have now put this idea virtually to bed, unless anyone could suggest a sensibly priced smart lighting system I could install myself??
Any advise or tips from you guys no matter how simple you think it is will be very welcome.
Thanks in advance for any advice or help
