Hi all,
Thanks for the comments.
Gary,
I cant see the "screen door" from couch, you would have get close to the wall to really see it. The middle row are "the best" as far as audio as I completed all of the SPL settings from the middle row.
I am still thinking about a screen but I don't like to rush my decision. I like what I get from the wall so I might give the boarder a try. Thanks.
Richard,
I like the idea of a false wall..I was going to have some stoarge units built from the same timber as the center unit and then have the speakers built into them with acoustic fabric accross the bottom half of the unit, but a false wall might just do the trick.
Thanks again for you comments and info.
Just as a side note all of the walls are installed with Boral Soundstop Accoustic batts and Soundstop Gyproc. The floor is floating on Regupol (sound prooffing) underlay as well, so the floor shakes.
Tom.
