New Home Owner - seperates on a budget!?!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by craynerd, Aug 10, 2005.
  1. craynerd
    craynerd
    Aug 10, 2005
    327
    Hi guys,
    I`ve just secured my first house and i`m looking to buy a full stack system / homes cinema for both quality and looks. Its an appartment so it has to look the part, silver and a nice stand, but most importantly its gotta sound good BUT i`m on a budget. I really dont have the money to spend what i want, so my question is,:
    Whats the best strack combination to buy for the money...?
    My parents have a sony STR-DB940 amp then full mathching sony seperates with it, I think thats amaizing, but i can imagine its out of my budget,,,
    so any ideas?, dont ask for an exact budget becuase its more of a case of saving for whatever i want.!
    Hope you can help
    Chris
  2. roversd1
    roversd1
    visit your local Richer Sounds, they will be able to sort you out.
    Looks wise - why not try the Cambridge Audio range, its looks completely different to the usual jap offerings
    The little Denon sytems are good too
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Hey Crane
    Yep check out the Cambridge Audio Azur range from Richer Sounds if your starting out, then go for their 540 DVD-V/Audio player, £200. Then route this to the £200 640 amp. Nice bargain starter kit. Nice silver finish (copied from NADs Silverline range)
    http://www.cambridgeaudio.com/categories.php?CID=4
    A few users on other forums I use use CA kit with £200 Castle Richmond 3s/Durhham 3s speakers & £200 Quad 11s – standmount speakers. If I were starting its what I would do.
    £500-600 and a lovely starter stereo system, that will handle CD, DVD-V & DVD-A as a bonus. You will also have a system that’s upgradable in future ie adding a DAC to the DVD player, adding a subwfooer to the standmounts or replacing amp & speakers etc.
  4. craynerd
    craynerd
    Aug 10, 2005
    327
    Thanks guys! great advice...!
    I`ve only had a quick look (i`ll look more closely later tonight) but how many seperates is that then? Just the two, dvd/cd and amp ? what about the tuner, and is there a MD player that matches? Also, with regards to cabinets, where do u guys get your stereo cabinets from?
    Chris
  5. craynerd
    craynerd
    Aug 10, 2005
    327
    Can i just ask, what advantage would i get in buying the Azur 540R – 6.1 AV Home Cinema Receiver over the 640 amp cjross recommended??
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Budget?
    5.1 or 2.0?
    Start here...
  7. craynerd
    craynerd
    Aug 10, 2005
    327
    ahh i c, would the reciever be a lot more expensive.??
    With regards to 5.1 or 2.0 ??? i`m just getting into this so you`ll have to help me out!!...whats the difference?
    Chris
  8. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    5.1 speakers - Front pair , Rear Pair, Centre & .1 channel low frequnecy effect LFE - subwoofer.
    2.0 Stereo - pair of speakers.
    Go stereo mate, better use of your money IMHO. You can still watch movies and listen from a stereo setup (thats what Ive done for years).
  9. craynerd
    craynerd
    Aug 10, 2005
    327
    right cheers. Isn`t 5.1 more like a cinema sound? Is a 2.o sterio just 2 speakers then or do you still have multiple speakers?
    Chris
  10. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    I have a stereo setup + dvd player.
    Now I would buy a 5.1 setup.
    But would prefer a good 2.0 to a bad surround for sure!
  11. craynerd
    craynerd
    Aug 10, 2005
    327
    since me and my girl watch a lot of tv and love watching a dvd most weeks, i think we would prefer 5.1 so we can listen in surround and get the full effect!
    Rather than going for a cheaper full system (like the cambridge audio recommended above, say £800 on the system), would it be worth me waiting and spending all the £600-800 on a tv reciever amp and speakers. Plugging the tv, dvd and reciever together to get use out of the amp, then a few weeks later, get the cd player ect. The thing is, i dont wanna get anything on credit!
    What tv reciever would you recommend and with what 5.1 speakers....i mean whats sort of cost am i looking at spending on something different....THEN a month or two later go and get the cd player to match, then eventually a tuner?
    ohhhhhh there is way to much choice!!!!!!!!
    OR lol, would u just wait, how much would i need to get a decent setup for music and dvd with 5.1 ?? AND another thing i`m getting a bit confused about, whats the difference between a home cinema and a hi-fi ?????? is it just the fact you plug the dvd and tv through the home cinema ?
    Chris
  12. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Tv receiver? I think you mean AV Receiver... (and the tuner radio is built in, so it's called a receiver)
    You allready have a DVD player? Which one?
    Maybe you can get something like a Marantz SR4500 or Denon AVR1905 and leave the rest for the speakers.
