New Hitachi 42PMA400E arrived - connection question
Discussion in 'Plasma TVs Forum' started by Stuart Wright, Mar 6, 2003.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    Hi All,
    just took delivery of a Hitachi 42PMA400E which has VGA, S-video, component and composite inputs.
    I will probably eentually drive it with a HCPC but until then I need to feed it a scart RGB signal from my TIVO. Without downgrading to s-video, how do I do this?
    Thanks.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    You'll need a John Sim RGB to Component convertor. It's unlikely the thing accepts RGBcomposite sync.
    If it does then you need a Scart to RGB COMPOSITE lead to go between the two and then you need to configure plasma to accept such a signal.
    Gordon
  3. Napoleon
    Napoleon
    Jan 1, 2001
    Given that you own a mighty impressive projector,i was just wondering why you had bought a plasma.I guess the performance is a few notches down the performance ladder,in comparison.Apologies for my noseyness.:)
  4. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    Thanks, Gordon - bits ordered.
    Napoleon - 5.1 system #2 for the living room.
  5. leigh h
    leigh h
    How are you finding the fan noise i didn't think they were bad at all,my fish tank makes more noise also I was told you can connect up dvd by using component to the vga lead to the vga port and changing the screen setting to component, is this possible because I am 99% sure I will be purchasing this screen. and a new dvd I have an old pioneer 717( no component), I think this screen is very good for the price I viewed this screen and the pio mxe and thought there was nothing in the screens that could warrent spending an extra 7-800 pounds maybe a slightly quiter fan operation.
  6. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    The fan isn't a problem at all. A complete non issue.
    The RGB to component convertor works fine.
    Most important for me is that John Archer rates it as the best plasma he's ever seen.
  7. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    probably just me but........who's john archer???
  8. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    The guy who writes most, if not all the TV, plasma and projector reviews for Home Cinema Choice magazine - of which's website, these are the official forums of. And who also writes the superlative hardware news for HCC, Total DVD and What Video websites.
  9. peve3
    peve3
    Aug 14, 2002
    438
    can u tell me if the Hitachi 42PMA400E supports pal progressive scan thx !! and where is the cheapest place to buy it !!
  10. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,604
    7
    167
    Birmingham, UK
    +10,471
    No I can't.
    Don't know the answer to the first questionand you can do your own homework when it comes to looking around for retailers.
    Don't forget to check the prices of forum sponsors. Give them a call they might budge a bit more forum members.
  11. mike.gibson
    mike.gibson
    Does the Hotachi have the option of taking RGB input as well as component (YUV). My panasonic allows you to set its inputs (via RCA) to either RGB or YUV. If using RGB you then set it up to take a composite sync signal from the normal composite video input. This way, using a SCART-RGB+Sync lead you connect your plasma to your normal RGB SCAR source. I guess you will need to check out the manual.
  12. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Mike,
    Seeing as Spectre asked how to plug things in and was given the suggestion to work out if it could do what you want....and that he has since gone and bought a RGB to Component trasncoder, I'd guess it can't accept RGBCompositesync....or he's just wasted over £100!
    Gordon;)
  13. mike.gibson
    mike.gibson
    U might be right - it will take a composite sync via one of its two 15-pin D-types, i.e. Analogue RGB+Comp Sync.
  14. leigh h
    leigh h
    According to a few threads and what the people at Nexnix told me on Friday, you can connect up using the RGB comp sync and that you can use the d sub and change it in the menus etc from RGB which it wont accept due to scan rate to component video and use component to d sub so I am afraid Spectre may have waisted the money on the converter but he might want to use his s video connections.
  15. datanet
    datanet
    The VGA ports can be reconfigured RGB....anyone any idea if there's a cable on the market (Scart to 15pin VGA)...or the pinout?
