New hifi cabinet
Discussion in 'Home Cinema Building DIY' started by Stereo Steve, May 24, 2004.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I have an alcove in a wall which is to house the new hifi unit. The wall is solid block. I was going to build a unit that I could pull out to get to the back but I'm worried about the sonic and aesthetic effects of coasters! So, while reading hifi news last night I hit an idea. How about fix MDF shleves to the wall on one of those adjustable shelf systems and build a false cabinet around it that can easilly be lifted away to give me side access to the gear and cabling?
    Sounds good but I'm wondering where I could get a shelf system strong enough to hold a heavy power amp. Any ideas?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If you use 3 or 4 vertical tracks rather than the standard 2 you should be able to inrease the maximum load and stability of the shelf. Maybe battens along the wall as well if necessary.
  3. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Yeah, any idea where I can get such a system? I don't think battens will be neccessary as it's a new block wall (not lite blocks) so some heavy steel rawl fixings will be fine. I would probably put a safety bar at the front just in case.
    I'm guessing you can get hifi versions of such a system but it's likely to be 10 times the price of a standard office one. The idea of having each unit isolated from the floor and each other is appealing.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  5. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Perfect..cheers.
    Pity I did a Screwfix order last night. :oops:
