new Hi8 camcorder for £99!!!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by fcat, Apr 2, 2005.
  1. fcat
    fcat
    Feb 22, 2005
    173
    16
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    err, a few errors with that advert me thinks :confused:
    It is listed as a Hi8 camcorder which obviously is an analogue format, yet it is also listed as having a digital zoom and a CCD sensor both of which are only found on digital camcorders.
    I think the most likely thing is that the camcorder is actuallly a Digital8 cam. If anybody is looking at getting this then you should do some resurch to find out exactly what the true specs are!
    Mark.
  3. fcat
    fcat
    Feb 22, 2005
    173
    16
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    My sony camcorder (about 5 years old) has a digital zoom, not sure about the CCD, but as there is no film to capture an image I can't see what would be different here between digital and analogue, other than perhaps resolution on more recent models.
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    No reason why a Hi8 camcorder shouldn't have digital zoom and a CCD. Its completely irrelevant with regard to the tape format.
  6. alistairgd
    alistairgd
    Say what? Of course Hi8 camcorders can have digital zoom, I have one right here made by Sony with 30x Digital Zoom stamped on the side! Never use the digital zoom of course, I canit think why anyone would ever want to once you see the effect, but regardless - there is digital zoom on analogue devices.
  7. profisheruk
    profisheruk
    [​IMG]
    yip this cam definitly has 880x dig zoom.i bought this a few weeks ago and is my first cam.if you look closely at the pic,its the same as a samsung camcorder,its just got a differnt name tag on it.it also takes samsung batteries.my father has a samsung cam which he bought about 2 years ago and they look exactly the same.he paid over £300 for his aswell.if your just getting into filming i'd recommend this has its easy to use.even for me.you can even upload your film to your pc if you install a tv card which is easy to install and you can buy from pc world for £25 :clap:
    see ya :hiya:
    johnr
  8. Timse1981
    Timse1981
    Its not aviliable currently.
