New here - help needed...
Discussion in 'General TV Discussions Forum' started by Bizness, Mar 27, 2006.
  1. Bizness
    Bizness
    Mar 27, 2006
    1,447
    2
    +221
    Hi guys, newbie here... needed some info and this seems to be the best place to go with my questions.
    I have pre-ordered Sky HD and need to buy a decent screen so that I can watch the impending world cup in HD.
    I want a wall mountable screen, but don't know whether to go for Plasma or LCD. Want at least 32", but realistically 40/42.
    What's the cheapest, most highly recommended TV based on these requirements, or alternatively, what's the best I can get with say 1200 quid?(although with a wedding coming up, could do with spending less)
    Cheers for your help guys... :smashin:
  2. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    Richer sounds are doing an Hitachi 42" HD-Ready plasma for 1200 notes.
    Failing that you are down to 37" plasma....although could probably stretch to a Panasonic 37"
    Not all that clued up on LCDs.....
  3. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,274
    Welwyn, Herts
    +942
    Bizness, if you are going to use SkyHD, and presumably DVD etc, does that mean you don't need an internal tuner? What you say "TV", that means a display with integrated tuner and audio.
    Without these, a plasma just becomes a display, or monitor, and may be better value if you don't need the all-in-one convenience of a TV.
    Can you also predict whether you are likely to to use it in a mostly dim or bright room?
    Nick
  4. Bizness
    Bizness
    Mar 27, 2006
    1,447
    2
    +221
    Won't be a particularily bright room, mostly dim, don't think the sun gets round that side of my house.
    Plus you are correct, integrated tuner not required... Any good displays then?
