Question New headphones £100 max
cirian75
For the last 10 years I've been through 5 sets of PC gaming headsets
They all break, they sound OK but the durability is poop
Logitechs, Soundblasters, Steel series
They are just not built to last
The cables are moulded in the cans and fray
The sliders and swivels for adjustment, thats their biggest weak point, even when you buy one that looks metal, as soon at goes inside the cans or arch, they attach by short screws into thin plastic.
I've had enough of them
Going the separate mic and headphones route
The microphone already is sorted
So looking a set of all round good sounding over ear wired so they block out other sounds, made mostly of metal headphones for £100 or less
Plugged into a PC Used for
Gaming, YouTube and movies, not a mega bass fan but I do like to have some.
Suggestions?
Fe_man2000
I am really not experienced in this area but I have got a set of hyperX headphone which I have had for 2 years now and are very comfy and have not had any build quailty issues, the cable is fully removable and hence replacable, but I havent had to do that so far. It has a mic but also is removable and I think they sound great. cost around £80 if you buy them at the right time, there may well be newer version of this out by now though.
Amazon product
