New head unit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by dingbat_stew, May 5, 2007.
  1. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    Im looking for a head unit with and front aux input for below £150. Also has to have pre outs for amplifier. Just wondered if anyone had any recommendations?
    Cheers.
  2. R-P
    R-P
    Feb 26, 2007
    29
    3
    Why frontinput? Rearinput/USBinput running to the glovecompartment may be even better (but I don't know your specific situation of course...)
    There's a ton of units that would fit your needs, try to narrow your search, like do you need one, two, three or four* sets of ourputs? CD or DVD? Pricerange? USB needed?
    Good luck,
    R-P
    *: some have dual-zone, therefor up to 4 sets...
  3. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    Well the only reason i thought about a front input is that it's cheaper to use a 3.5mm male to male jack cable than buying a head unit with ipod interface, because they do the same job.
    Only need cd player, 1 or 2 pre-outs and don't need a usb connection.
    Cheaper would be better cos im pretty skint but i know money is quality so i would spend anything up to £150.
    Tried to be a bit more specific!
  4. nortonl
    nortonl
    Oct 4, 2004
    167
    +7
    Not necessarily - some head units can control track selection but you will have to use the iPod controls if you use 3.5mm input. You may prefer this anyway of course.
  5. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    Yep i don't really need to use the headunit controls. I don't mind using the ipod controls and so effectively they do the same job but for less money.
