AntoniHallman
I upgraded my 40GB HDD to a 320GB yesterday after reading that the back up utility saves all save game data without needing to back up to an external storage device so I thought that was great because I don't have an external drive big enough to store 40GB worth of game data.
I went to the back up utility and proceeded turning down the option to back up externally. I then replaced the HDD with the new one and performed the 'full format'. When trying to restore the data from the back up utility it asked to connect the external device so I though, **** I have just lost all my data.
I didn't format the old HDD before taking it out so the data should still be on there, correct?
If so, is there a cable i can get to connect the old drive to the usb?
If not, is there something else I can do now to get all my data back?
I know I'm a bit of a tit but any help will be much appriciated, thanks
