New HD Forum loop @ 5°W
Discussion in 'General TV Discussions Forum' started by Abstrakt, Sep 11, 2004.
  1. Abstrakt
    Abstrakt
    Dec 12, 2003
    247
    28
    +40
    The test channel for the French HD Forum has switched back to MPEG-2 [email protected] They’re currently broadcasting a new high def loop for the IBC taking place in Amsterdam this week.
    Atlantic Bird 3 @ 5° West:
    11677 V, SR: 25000, FEC: 1/2
    VPID: 528, APID: 529, ID: "channel 0000"
    Provider: "EVS Broadcast Equipment"
    1920x1080i @ 25fps
    Enjoy!
  2. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Good Morning Abstrakt, I have the TF1 Channel tuned in, Channel 0000. It looks good, it is basically the same as before with lots of new clips added, including some very nice aerial shots of Paris. It is about 70 minutes long and it is still showing the overscan lines at the bottom like the original loop they had on Hodbird 13E.
    Is there some place in MT where I can read the resolution and frame rate?
    Jim
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,269
    Manchester
    +758
    That's quite a nice loop.
    I can confirm Abstrakt's tuning parameters
    Datarate is 18 Mbps.
    Chris Muriel, Manchester.
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I can't seem to view this channel with a skystar 2 card and ProgDVB, I just get a list of data channels on 11677 ??
  5. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    RecordableDVDfan, I am using MyTheatre with Nova CI and it jost finds it on a scan, ID is Channel 0000
    Jim
  6. Abstrakt
    Abstrakt
    Dec 12, 2003
    247
    28
    +40
    Hi Muf,
    Not as far as I know; unless you record a short clip and play it back in a player that lists such information... I used TSReaderLite to get that info.
    I thought those film clips looked pretty good. One of them, Les Rivières Pourpres (The Crimson Rivers) should be coming out on WMV-HD DVD before the end of the year in France.
    Cheers.
  7. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Thanks Abstrakt, yes I think this entire loop is excellent. Are you using MT with a positioner? I haven't tried it yet, I just have a dual LNB with one output connected to a cheap FTA box with DiSEq 1.2.
    Jim
  8. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Well I'm now running MyTheatre but it does'nt find this channel just 2 globecast testcards as I type this plus a few scarmbled feeds etc, guess it's off air for now ?
  9. Abstrakt
    Abstrakt
    Dec 12, 2003
    247
    28
    +40
    No, I don't use DiSEqC at all. My actuator is controlled by an old analog Pace receiver.
  10. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Thanks Abstrakt.
    RecordablDVDfan, it is still on and it is the only channel I am getting on that transponder.
    Jim
  11. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Ok nothing here anyway
