New Harmony Advice
Discussion in 'Home Cinema Control & Remote Controls' started by superdon, Feb 27, 2014.
  1. superdon
    superdon
    Dec 31, 2003
    1,727
    48
    +66
    I need some help with a new Harmony for the lounge, to replace the old 885 which broke a few months ago.
    I don't want to spend a lot, so was looking at the 650. But, the Smart Control system can be had for just £15 more. I am just not sure it would work for me.
    In the lounge, we have the AV receiver and a Tivo box in a closed cabinet. The TV is outside the cabinet. I currently have a RF system to pass the IR controls into the cabinet. A slight added complication is, that I also have control of the Tivo via a second RF system to allow us to control the Tivo from the cellar from a Harmony 1100. All the RF things I have are Powermids and work ok.
    Would the Smart Control work out of the box for me, or am I beter just going for a 650?
    Hope this makes sense!
  2. logiciel
    logiciel
    Feb 2, 2008
    53,136
    UK
    +5,775
    The official difference in price is £40, so I'd definitely go for the 650.
  3. superdon
    superdon
    Dec 31, 2003
    1,727
    48
    +66
    Well, its about £50 from Amazon for the 650. But, currently the Smart Control is £80 but with £15 voucher back, which I would use. So effectively about a £15 difference.
    As long as it will work for me and is worth it, I don't mind paying a few more quid for a better solution.
  4. logiciel
    logiciel
    Feb 2, 2008
    53,136
    UK
    +5,775
    I was going by the Logitech pfficial prices but they are known to be variable.
    There's no mention at Amazon of £15 back but doesn't that apply also to the 650?
    The Smart control is meant to work in conjunction with a telephone or tablet.
    If you want that then it is obviously the better choice - otherwise not.
  5. superdon
    superdon
    Dec 31, 2003
    1,727
    48
    +66
    No, the £15 doesn't apply to the 650 unfortunately.
    I suppose the main query is, with my set up (tv outside cabinet and AV inside cabinet) and current use of RF, will both the Smart Control/or the 650 work without me needing to buy anything else.
  6. logiciel
    logiciel
    Feb 2, 2008
    53,136
    UK
    +5,775
    Yes, but "The Smart control is meant to work in conjunction with a telephone or tablet".
  7. superdon
    superdon
    Dec 31, 2003
    1,727
    48
    +66
    Went with the Smart Control for £65 after Amazon's £15 offer. It arrived today and its fantastic. Took about 20 minutes to install and configure and works brilliantly. I won't use the apps too much but the basic controller is great for our lounge.
    I might even think about replacing the 1100 in thecellar, although not sure if its quite up to that.
    For a simple set up, the smart control is brilliant, well impressed.
  8. DannyBoy1
    DannyBoy1
    Dec 28, 2006
    550
    +15
    not seeing the amazon £15 voucher offer where is it?
  9. superdon
    superdon
    Dec 31, 2003
    1,727
    48
    +66
    I think it finished yesterday, it was a one week promo.
