New Hard Drive
Discussion in 'Computer Components' started by neilo, Sep 7, 2004.
  1. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
    Needs a new internal hard drive How can I tell which one I need re connecters ? Has a 4 year old Dell
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    This will use the standard IDE connector - so you need to buy a HD that is IDE not SATA.
    Also, its unlikely your PC will recognise any hard drive bigger than 60 or 80 Gb due to BIOS limitations.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Um, I think it's probable the BIOS will support up to the 137Gb limit, unless Dell used very old BIOSes. I have 2 machines with 1999/2000 BIOSes and both have LBA support meaning 120Gb disks are used in their entirety.
    Also, AFAIK neither 60Gb nor 80Gb was a 'magic number', 32Gb and 137Gb were indeed limits at various times in the evolution of the IDE standard and BIOS support but I've never come across other limits .. again, this is with generic BIOSes, I know Dell can be, er, creative at times. ;)
    What is undoubtedly true is that this PC will NOT see beyond the 137Gb limit since its' BIOS will not have BigLBA (aka. 48-bit) support.
  4. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
    so a 120 gb max then ? I will be adding it as my 2nd drive can I forsee any probs ?
  5. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,488
    South Derbyshire
    +198
    120gb would be good - even if you didnt use all of it - it might be useful in a future machine. Plus its 120gb & 160gb drives are sooo cost effective these days.
    My IBM Aptiva, which I bought in Dec1999, wouldnt see anything bigger than 60gb - how lame was that?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    :eek: ... certainly I've never seen such a limit before, but then I've never used proprietary systems like Dell and IBM, instead I've built from components.
    Neilo: you may want to give Dell a call to check. They will (should) have a record of your machine's tag number and should (hopefully) be able to give you the definitive answer.
    OTOH, their call centre is in India and getting to talk to someone who (a) you can understand and (b) knows anything technical can be, er, challening at times as I know only too well from work. :rolleyes:
  7. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +482
    Can't the BIOS be flashed to enable support for a larger drive?
    Or is it the case that you can't get BIOS upgrades for DELL machines?
  8. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,797
    41
    Kent
    +18
    Just to let you know...
    I have a 1999 Dell Pentium III XPS-T450 (Bios A11) running XP-Pro with 3 Seagate Baracuda 200gb GB Drives in it as a streaming media server and it works just fine. The drives were £65+VAT
    Search here for your Machine and Operating System and you should be able to find the latest bios upgrade.
    Mark.
  9. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
    wow cheers Mark will look into that
