New graphics card needed
Discussion in 'PC Gaming & Rigs' started by wiz, Dec 5, 2003.
  1. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Hi guys
    Bought Need for Spped underground but it won't run. Comes up with the splash screen then goes. I think my graphis card is not up to it!(Hercules 64mb KyroII).
    Could you recommed a card that will run Need for speed underground got up to £150 to spend, but just want reasonable card.
    rest of system
    amd 1700+
    512mb ram
    jetway 687as mother brd
    xp home :confused:
  2. Kramer
    Kramer
    No point in anything too powerful (your CPU will be the weak link) so something from ATI, maybe a 9600 variant?
    Other threads here recently with loads of suggestions in the £150 region - last few weeks IIRC.
    :smoke:
  3. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Ok!
    Thinking of upgrading processor amd motherbrd eventually. What do you recommend???
    :D
  4. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Dual opterons mate!! :)
  5. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Can you suggest which bank i need to rob?
    :D
  6. Rich
    Rich
    Sep 15, 2002
    2,239
    warrington
    +134
    have a look at dabs "b grade" section of their website,you can get some really good offers there.
  7. Erpland
    Erpland
    :confused: And there's me saving my pennies for, in my book a 'powerful' 9600
  8. CENSORED
    CENSORED
    You have a 1700+, if it's one of the magic ones you could do a lot worse than partnering it with an Abit NF7-S motherboard and applying a smidgeon of overclocking.
  9. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Wos that then, how do I tell if it's a magic one?
    Can anyone recommend a good motherbrd (AMD compatible)
    :hiya:
  10. Erpland
    Erpland
    You've got 150 to spend on a GFX card, and now you're also considering buying a new motherboard just to overclock a AMD 1700 :rotfl:
  11. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    No. I Will update CPU as well!
  12. Erpland
    Erpland
    good on ya
    but doesnt your board take an xp2200? theyre only £46,
    spend £105 on the GFX card and your laughing.
  13. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Tried a 2100 it wouldn't even boot so thoght sod it! I'll upgrade in stages ( hiding reciepts from wife)
    :D
  14. Kramer
    Kramer
    If it's a "magic" XP1700+ (DLT3C) it should be good for at least 2.2/2.3gHz :eek:
    I've several of these & they're all happy @ 2.4/2.5gHz with low voltage (watercooled though).
    IIRC, they cost <£50.
    :smoke:
  15. Erpland
    Erpland
    heat and noise permitting,that kind of overclock would be worth changing the mainboard.
  16. mjr600
    mjr600
  17. Kramer
    Kramer
    That's the beauty of those chips, they don't get too hot when overclocked as only a very slight v core increase is necessary, say 1.65v (they're 1.5 v core "standard" IIRC).
    2.2/2.3gHz is easily achieveable with moderate air cooling (read: practically silent).
    :smoke:
  18. Solar
    Solar
    Dec 2, 2003
    2,542
    Earth
    +478
    yup, i just got myself a 256mb GForce FX for £104, well impressed.
    but where my GF lacks performance, my old ATI 9000pro "128mb" kicks its ass (seriously)
    so wiz if you want a good graphics card go for the ati 9600 256mb
    its £25 more than the GForce FX but you will be getting at least a £100 worth more from it
  19. Ashy
    Ashy
    Jan 3, 2003
    350
    get yourself a 9600xt, if your after a motherboard look at the nforce2 ranges. you cant really go wrong with epox/abit/asus.
    however, you would see a bigger boost in performance if you got yourself some high speed memory, get a pair of 3200 ddr sticks and you will be laughing. (for running in an nforce2 board that is)
  20. wiz
    wiz
    Aug 20, 2000
    3,322
    +2,054
    Thanks guys!
    Settled on a MSI FX5600XT in the end. £99 from computer fair, seems ok for now
    :clap:
  21. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    Hi wiz, I've got a Gigabyte 7NNXP motherboard with a AMD 2800+ chip. It's a good stable board IMO, and it has SATA and 4 duel ram slots.
    ASH1
