new future proof!?! P.Scan system
Discussion in 'Projectors, Screens & Video Processors' started by MattJTC, Apr 3, 2002.
  1. MattJTC
    MattJTC
    Hi all, new here and 1st post!
    I'm looking to build a new home cinema setup bit by bit. First is the DVD player, I'm keen to get a progressive scan unit as I understand that sonys new CRT TV's, due september, will be 100Hz progressive units -NTSC and/or PAL ????
    So what player should I get now for max compatability?
    The Denon DV2800 cannot (ever?) do PAL progressive?
    Can the Arcam FMJ DV27 do both? Unofficially? Could there be issues down the line?
    And last but not least which progressive should you go for!? 480p,720p e.t.c.
    Might a decent cheap player (Tosh210) be a better call right now?
    Sorry to go on! Hope someone can shed some light!?
    Matt
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,740
    7
    2
    167
    Birmingham, UK
    +10,630
    Get a PC for the ultimate in home cinema upgradeablility.
  3. MattJTC
    MattJTC
    Currently watching a DVD on WinDVD!
    Do PC's put out progressive signals to TV??
    M
  4. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    I thought there was already a hack out for the 2800 to do pal progressive?
    Dave
  5. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,774
    Outpost 31
    +215
    Yep, the Denon does PAL progressive if the hacked firmware is used (which also provides multi-region playback etc). Do a search on the internet and you'll find it eventually. I'm sure there was also a link given in this forum some time ago, so do a search here as well.
    Regards
    Paul
  6. Stuart Wright
    Stuart Wright
    Jan 24, 2000
    14,740
    7
    2
    167
    Birmingham, UK
    +10,630
    No but then there aren't any TVs which can accept a progressive scan input.
    You'll need a projector. The £1500 Panasonic is currently very popular.
  7. MattJTC
    MattJTC
    Cheers will look for that Denon hack....... does hack mean it has issues? Or it works perfectly (well as good as the NTSC) its just not been licenced?
    Matt
