Question New fronts and centre
Discussion in 'What Speakers Should I Buy?' started by shaolin kid, Jul 1, 2015.
  1. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    I m looking at buying the new denon 4200 amp to replace my ageing denon avc a1se and replacing the LCR speakers of my m&k thx select speaker package because the can't handle some of the heavy action on some blu rays (pop badly) my question is would the B&W 685 S2 and matching centre be a good replacement? Can't really stretch to new m&k speakers so I'm looking for another option....any thoughts greatly appreciated
  2. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    Coventry, West Midlands
    +2,432
    What crossover point are you using for the M&Ks? And which ones are they?
  3. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    My denon amp just has large or small speakers so are set to small,so bass redirected to amp.unless I've missed something all this time there are no other options. The m&k are the 750 I think,part of the thx select package
  4. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    By the way they only pop on blu rays and only certain films,does the hd audio on blu rays have a lower bass frequency that the speakers can't handle? Never once had an issue when watching dvds
  5. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    No - audio from DVD and Bluray won't make any real difference to the speakers, so it shouldn't matter as you're still using the same crossover point (minimum 80Hz) regardless of the audio format.
    I can't see any speaker in the budget you're looking at taking as much as the 750s will. What you might be experiencing is the difference in power between your previous and current amplification.
  6. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    I'm still using my old trusty denon avc a1se amp until the new denon 4200 is released.if the audio from dvds and blu ray is the same how come they only pop with blu rays?
  7. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    Something wrong there then. The 750s will happily play reference level in any normal living room providing the amplification is up to it. How are you sending the Bluray audio into the A1?
  8. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Using digital coaxial mate.
  9. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    The only thing I can think of off the top of my head is that maybe the output signal of the Bluray player is a little high for the input of the Denon, causing it to clip or something. It has been a while since of seen an A1, but do you have the input level trims on that model? If so, you could try taking that down by a few dB.
  10. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Off the top of my head I can't remember seeing it as an option but I'll have a look
  11. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Just another question mate.so should my m&k happily cope with hd audio then? If so it will save me buying new front 3 and just needing some for atmos and dts x
  12. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    They'll be fine. I used to have a 750 setup with Bluray as a source without any problems. It's just a case of narrowing down what is causing the issue.
  13. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Well that'll save me a few bob ☺ on the individual channel levels for each speaker I have the bass set to 8 and treble on 12,would this cause the popping on the blu ray? Is fine with dvd though
  14. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    It could well do - try a Bluray out and see how you get on...
  15. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Will do,just have to remember which film and scenes cause the issue
  16. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Ok,I looked for a input trim....nothing and I also lowered the bass and treble output to each channel but could not stop the front popping at all.i played interstellar (the launch and separation scene) made the L and R channel's pop badly,I've tried everything available on amp and blu ray player but with no success....the only thing I have nt tried yet is hooking up my old bw 602s to use as L R to see if this cures it,if it does the I'm looking at new LCR speakers
  17. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    Are you sure they're set to small? With bass and treble all on 0, and set to at least 80Hz, the bass/mid driver excursion should be minimal.
  18. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Yeah definitely all small,I even went -db on bass it still popped.
  19. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    Definitely something not right!
    Can you hear anything wrong at lower volumes? Does it only happen when played loud?
    I presume the audio decoding on the Bluray player is either set to downsample to Dolby Digital and DTS via the optical output, or set to PCM?
  20. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Set to dd and dts so the amp decodes,I do listen to healthy volumes lol but no higher than dvd levels.
  21. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    Is there an option for setting sub output to "both"? This sends low bass to sub AND speakers...
  22. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    No mate,on the amp there only the option to set the size of the speakers so bass is redirected to sub.....lol where you live? Come round and have a look
  23. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    That'd be much easier! That'll be tricky though if you're not Birmingham/Coventry based...
  24. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    ☺ as you can see from my avatar....hull mate..bit far eh
    I just find it funny that even if I lower the bass to -db it pops but watching dvd at + db bass on LCR produces no popping at all.if they were damaged then I would get that all the time
  25. hifix
    hifix
    Mar 7, 2006
    12,284
    2
    +2,432
    Ah yes, didn't see that!
    Your situation is odd. Yes, if they were damaged, you'd get the popping even with DVD. Because of that, the only thing I can think of is the audio settings on the Bluray player in relation to Blu-ray Discs (I'm presuming you play your DVDs on the Bluray player).
    Might be worth getting a local dealer in to check things out - or maybe a helpful (and local) AVF member...
  26. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Yeah play all discs from same source.hmm I wonder if there are any local AVF'S?
  27. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    I finally got around to trying my old bw 602 speakers as L and R and to my suprise the distortion is still there on the lift off scene in interstellar,now this has me thinking I have some sort of issue with my amp (an old denon avc a1se ) very annoying and frustrating not to be able to find the problem and solve it.i am considering a new amp,maybe a denon 4200 or denon 7200 and I WAS thinking of new LCR until I tried my bw 602s but seen as the distortion was present when using them also that negates the need
  28. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Any av enthusiasts with tech knowledge live in hull? Might be better making a separate thread to request help
  29. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Do you have a sub?
  30. shaolin kid
    shaolin kid
    Jun 19, 2011
    1,552
    +409
    Yeah mate,i have the miller and kriesel 750 thx select package
