New front three
Discussion in 'Home Cinema Speakers' started by Thunder, Sep 21, 2005.
  1. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    After a new front three to replace my Missions. Max budget would be 3k, any suggestions :thumbsup:
  2. recruit
    recruit
    M&K S-150's as the front 3 if Home Cinema is you're preference :thumbsup:
  3. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    John, how much are the M&Ks?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    RRP is £875 each
  5. recruit
    recruit
    Yep pretty expensive but i would also consider the ST tilt stands to go with them which would whack another approx £300 per speaker.. :eek:..the Pro versions can be had cheaper and some people say they sound slightly better but i have heard them and could not tell the difference as to me they sounded exactly the same as my S-150's...
  6. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    Sell your amps and put the addtional funds into some actives, Genelecs?
    I also am a fan of passive Kef Ref's, but in owning some it is overly predicatable that i would say that.
  7. recruit
    recruit
    Genelecs certainly seem to be the flavour of the month for alot of people now, still not managed to listen to any yet though. :(
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I've heard two different Genelecs and they are fine speakers well worth the buzz that's been created if actives is what you want. Perhaps a little more laid back than M&K
  9. recruit
    recruit
    Cheers Ian - I suppose though that is what i like about the M&K's and they are certainly not laid back, i will still have to listen to some Genelecs as there is so much talk about them recently.. :)
  10. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    923
    46
    +114
    GENELEC :D
    Seriously though.
    Are they for a movies only based system or music as well?
    Do you have any aesthetic constraints to adhere to?
    What will your listening distance be?
    The last one is important.
  11. recruit
    recruit
    :nono: ........ :D
  12. Madders
    Madders
    Jan 30, 2002
    2,666
    71
    London
    +62
    Having owned M&K S-150's | have to disagree with that Ian, with the metal tweeter they (in my opinion anyway) verge on bright to sometimes harsh but certainly not laid back.
  13. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Thanks but Ive heard M&Ks on the end of Tag before and found it too forward for my ears :( . I'm not really a believer in the whole THX 80hz cut off. Ive always found larger speakers more pleasant to listen to, my 783s are cut at 40hz and the 752s at 50hz as I generally find that when subs try to do upper bass things start to sound lumpy and less agile (just my opinion of course) So floor standers would be better for me :) I do listen to music about 40% of the time :thumbsup:
  14. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I have the Steely Dan "Two against Nature" DVD which I can't play on my Denon M&K combination as the sound is so harsh that it grates my teeth but it sounded fine when my M&K's were swapped for the Genelecs.
    Anyway, to ensure that I don't get into trouble with the moderators for taking this thread Off Topic I would like to recommend that Thunder have a listen to the PMC range as they would be high on my list to audition carefully with his sort of budget
  15. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    1.) Movies and music but mainly movies
    2.) Not really its all in a dedicated room
    3.) around 4m
  16. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    923
    46
    +114
    IMO Genelecs are excellent for both films and music. They won't win any beauty contests though, especially the larger designs. But you're in a dedicated environment, so that is a moot point.
    The distance you are listening from will mean you need to look at the larger models of any manufacturers range, but for the Genelec range I would start with a minimum of the 8050s (2 way design, 8" woofer, 1" tweeter, 150W per driver, 38 Hz - 20 kHz ± 2 dB, 120dB peak per pair @ 1m).
    As Ian has said, also look at PMC's range - again, I would suggest the bigger models and prefereably active. :devil:
  17. recruit
    recruit
    Yes i have read elsewhere that the Tag & M&K don't go to well together :( shame really as they are very good speakers.
    Ref to the 80hz Xover i have always found it to work quite well in my room and so i feel the complete opposite, i have had floorstanders too in my room but always found the 80hz to be the best point in regards to intergration.
    I think Godfather has bought or is buying some of the Big PMC studio type speakers which look pretty cool and i presume will sound excellent too although they are on the expensive side well above 3K!!
  18. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Any opinions on ATC?
  19. Madders
    Madders
    Jan 30, 2002
    2,666
    71
    London
    +62
    ATC - Awesome speakers! Should definitely be on your audition list along with PMC,Genelec,M&K etc
  20. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    923
    46
    +114
    I demo'd the Active-10s and found them very boring. You may draw a different conclusion, of course. :)
  21. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Boring? The very last thing I'd have said!
