New flat, odd shaped room & 6 speakers???
Discussion in 'Home Cinema Buying & Building' started by richgtfc, Mar 15, 2005.
  1. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    Just bought a new flat :clap: which I move into at the end of April. However, the front room is an unusual shape and I'm struggling to work out where I'd put my 6 Kef eggs. I'd like to keep the rear surround, but if not possible then it doesn't matter.
    I've drawn the room to scale and added a couple of positions of the TV & speakers. Do any of these look OK. You may notice the sofa doesn't quite fit :rolleyes: but as it's only a year old it's not getting changed.
    Any help would be great
    Cheerio
    Rich
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Why not shove the TV into the corner where the Sub is. Depending on the size of the Sub, you might be able to leave it behind there anyway. View the TV diagonally from the other side of the room. Have the rear left speaker in the position in Pic 1 and the rear centre and rear right in the position in Pic 2.
    Just a thought.
  3. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    Cheers for that, I should have mentioned in the post that I plan to get a plasma in the next 6 months, so would have it flat on the wall in either of the 2 positions in the drawing.
    Your suggestion would be ideal for my initial set up with a TV and is probably what I'll do.
    The flat is new and has no flooring yet so I was wanting to get some speaker cable laid prior to wooden floors going down. The speaker cable would be laid based on having a nice shiny plasma in place on a wall, rather than the telly in the corner.
    Choice of plasma will be another issue.........
    Rich
