New flat - new problems
Discussion in 'Home Cinema Buying & Building' started by jimmini, Mar 18, 2006.
  1. jimmini
    jimmini
    Mar 13, 2005
    11
    Bristol
    I've done a search for this and can't find anything... so here I go!
    Moved into a new flat. its a new build, quite posh, but its got -
    -Wood laminate floors.
    -Wooden blinds.
    -Only my rug and my couches are soft things in the room.
    Its a rented flat, so I can't pull the installed blinds down and hang curtains, and obviously ripping up the floor is no good.
    What can I do to get my low range back and get rid of the reflections? or is it a loosing battle? I run a 5 speaker setup, everything is currently just on spikes - I suspect this might be my first problem?
    I'm on a small small budget.
    thanks in advance!!:smashin:
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    free standing acoustic screens is your answer, but on alimited budget, you will have to make your own
  3. jimmini
    jimmini
    Mar 13, 2005
    11
    Bristol
    care to expand a bit :) ?
  4. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    make yourself some absorbing panels that you can move out the room or store while in 'normal' use, simple timber frame with a rockwool panel inside, fabric wrapped, i have a picture of a commercial version but rules mean i cant link to it
  5. jimmini
    jimmini
    Mar 13, 2005
    11
    Bristol
    cheers mate. I could hang them up as plain old pictures even ?
    thanks for the time.
  6. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    yes you can, some manufacturers even supply baton mountings for some products(wink wink) to allow for such a thing!
  7. jimmini
    jimmini
    Mar 13, 2005
    11
    Bristol
    is anyone going to send me a link for these wink wink products :D :D
  8. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
  9. samg
    samg
    Mar 26, 2006
    9
    how important is wood laminate flooring to sound quality? i have this in my soon to be hc room.
  10. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
  11. pwood
    pwood
    Dec 6, 2003
    2,608
    Central Scotland
    +178
    Laminate flooring is not gonna help achieve Nirvana. Its easy to keep clean and it looks nice but you will need a nice big rug on the floor.
