New flagship Pioneer amp
Discussion in 'AV Receivers & Amplifiers' started by kentlad, Jan 7, 2004.
Tags:
  1. kentlad
    kentlad
    Oct 28, 2003
    Just about to purchase the VSA-AX10i amp for my new rig.
    However notice that av-land are advertising the new VSA-AX10Ai (also mentioned in HCC recently), apart from supporting WMA 9 and having a bit more beef. Does anyone know any details and more imortantly price?
    Will the old model be reduced in price? Don't really want to go and splash out £2075 (cheapest I have seen so far), only to find the new ones comes in at the same price or the old one comes down by a few hundred.
    Purchase / install looking likely for early feb, any info greatly appreciated.
    Ian.
  2. wizbongre
    wizbongre
    Jun 24, 2003
    592
    Liverpool, Merseyside
    +63
    Sorry, don't know about your query but just wondered what WMA 9 is?!
    Thanks!
  3. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    Windows Media Audio version 9 :)
  4. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    kentlad, hold fire till you know more. Ive seen some members swap the 10 for the 5 as its almost the same for half the dosh!
    ch
  5. nobby
    nobby
    Dec 28, 2001
    605
    46
    wee Norn Iron
    +141
    in response to the last post ...
    is the 5, the same as the 10?
    what is better on the 10?
    i am thinkin of upgradin my yammy ax1 to the 10 due to the xtra sound processin, thx etc.
    should i look at the 5 as a reasonable successor to this monster amp i currently own
    thanks for any advice
    nobby:
    confused: :eek:
  6. russraff
    russraff
    Aug 1, 2000
    2,413
    Newcastle
    +63
    The AX5i is nowhere near as good as the AX10i. They may share some features, but the sound from the AX10 is much better. The AX10 has THX Ultra2 processing and the auto setup is more elaborate on the AX10 amongst other things.
    Russell
  7. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    AX10 also has video up conversion to component.
  8. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Hmmm, I think it's a bit strong to say that the AX5 is nowhere near the AX10 in terms of performance.
    Sure the AX10 has more frequency bands in it's MCACC, has more power, does component video up conversion and has a higher level of THX certification but I would still say the improvements are minimal for the price difference and most people would need no more than an AX5.
    My suggestion is to trial them both and see if the additional spec' of the AX10 is worth the extra cash.
    The AX5 actually gets a best buy in one of the audiophile Hi-Fi mags (don't remember which) as a very good stereo amp.
  9. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    the AX10 IS better, than the AX5i.
    but it also demands high end kit to partner it, to get the best out of it. It also has much better grunt and dosent distort at higher volumes.
    the AX5 however is a good compromise if you have a smaller room.
    the new ax10 also features dolby prologic IIx. its more of an update.
    However there are a few new amps about to hit the market that feature HDMI switching and a host of new features.
    now is not a good time to spend loads on an amp. wait a little bit to see this years new products.
  10. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Ooooh! Didn't know that.
    I wonder if they've also put a USB port on it now (and iLINK)?
    If/when they incorporate an HDMI port with HDMI up conversion from component/rgb, etc. then I'll get one.
  11. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    True, the AX10 has a more stable power supply, a tad more flexibility, higher build and the 9 Band Equaliser with MCACC (as opposed to the AX5's 5 band).
    The power output difference is unexpectedly tiny. THe AX5 delivers 105 watts into five channels, the AX10 shrinks to about 120ish. Frankly, the two are so close in specification and so similar in sound, that most people will struggle to find reasons Why Not to buy the AX5, and stuggle more-so to find reasons why to opt for the AX10 over it.
    If you biamp the front channels on the AX5 I'd imagine the gap would be lessened further still.
  12. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    170watts equal power out put into 8 channels.
    170watt in stero mode.
    the new AX10ia is 200 watt
  13. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The AX10 isn't 170 watts into 8 Ohms, it's 170 watts into 6 Ohms.
  14. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    yes your right its 150 watts into 8 channels at 8 ohms
    the ax5 is 100 watts @ 8 ohms
    ax5 also = motorola 150mip 48bit pro (x2) DSP
    and 1 192/24bit dac
    AX10 i = SHARC 32bit (X2) and 48bit(24bit double precision)
    also 192khz/24bit dacs (1 for each channel)
    but i think i would buy the yamaha Z9 if i was going to buy an amp today.
