Sadly GDPR means we can no longer offer access to AVForums via the branded app or Tapatalk.
New firmware for SONY HX900!?
Discussion in 'Blu-ray & DVD Players & Recorders' started by maddi, Jan 31, 2005.
  1. maddi
    maddi
    Without beeing too optimistic...
    I read in a German forum that someone will definitely send a HX900 to support in order to do a firmware update beeing available since late January.
    If this is true, maybe some major drawbacks will get a correction.
    Maddi
  2. Pilch
    Pilch
    Jul 10, 2004
    110
    Nottingham
    +5
    *crosses fingers for divide function*
  3. maddi
    maddi
    First unofficial bug fix notes of new firmware for this beauty.
    - problems recording encrypted video signals from some pay tv channels
    - no display of channel names (?)
    - no automatic clock setting through some channels
    - brightness jitter in transitions from bright to dark scenes (?)
    For me this short list is a bit ambiguous, but at the moment I don't have more detailed information. It really looks like a rather rudimentary release, just to fix some major bugs - which I can't see with my unit :( .
    But, let's wait for the unit to be returned.
    Maddi
  4. Chris at Home
    Chris at Home
    I found that the standard timer settings are disabled by setting times by Videoplus which scans all channels for a trigger signal. If a scan is taking place, the record button on the remote control also gets put out of use. You MUST disable the VP scan to use the record button if a "must record it now" situation arises. If you need to use the standard timer, then NO Videoplus times may be set. Presumably, in some countries, not all TV stations transmit Videoplus. How do they manage with a mix of standard times and Videoplus times?
    Incidentally, I found the Videoplus functions to be a bit inaccurate, especially when one programme follows another. A 1 minute gap between times would be fine but I suspect that the TV companies want us to record all the adverts as well!
  5. JethroUK
    JethroUK
    Dec 5, 2004
    1,144
    +34
    Videoplus doesn't transmit any signals - i think you're get mixed up with PDC
  6. Chris at Home
    Chris at Home
    Actually, the Sony manual refers to it as "PDC/VPS" throughout the timer recording section. :confused: That's what got me mixed up.
  7. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Emailed Sony about firmware update & got this reply:-
    Thank you for your recent enquiry.
    "We have got no information saying that there is going to be a firmware update for this model. It is very unlikely that there will in fact be an update to this model, however if there ever were to be a firmware update this would be detailed in the support section of www.sony.co.uk.
    I am sorry we could not assist on this occasion."
    Doesn't look too hopeful. :(
  8. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Any of this story remind you of the recorders from a certain company whose name begins with "P"?
  9. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Yes - I've noticed a lot of posts about "Panasonic"
  10. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Mainly ones saying how good they are ;) Don't worry Ivan - maybe one day you'll convince yourself that the Philips you brought wasn't a lemon :) Maybe...
  11. maddi
    maddi
    Having read several complaints about Canadian, US and German SONY customer support you shouldn't expect any information on new firmware releases for standalone DVD players or recorders. Until now, two HX900 owners told me they sent the unit to a local service provider and got it back with a new firmware. Asking for the changes they got a short list of corrections. And, yes, SONY CS denies that a new firmware exists.
    I definitely will try to get it from a local service point.
    I got my own experiences with the CS the last weeks - they don't know much.
  12. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Please keep us informed :)
  13. Chris at Home
    Chris at Home
    Are the Sony staff treating us like mushrooms? (Fed on bull**** and kept in the dark!) My HX 900 is fine if you don't want a "divide" function. That doesn't worry me too much because my attention span is little more than 1 hour!
