TL;DR: Do I put L&R at the blue or yellow triangles? Do I put rears at red or purple triangles?
Hi all, newbie post here. I've dabbled with surround sound setups for many a year now between budget floor standers as a student, to something more discreet and small form factor in the lounge at present (though massive compromise on placement). We are having a new extension built, and I'd like to get things as good as I can from the get go particular around speaker placement. I do however have to make compromises with style, layout, budget etc to keep Mrs Jaffaman happy (style, no floor standers or indeed floor stands, unobtrusive etc)!
I'm aiming for a Dolby Atmos 5.1.2 setup. What I would really like some advice on is positioning of the fronts and rears if you would be so kind!
Mrs J had particular niggles with the centre channel - she wanted this wall mounted and not sat on a unit beneath the TV. I've therefore gone for a Monitor Audio Apex A40 (second hand ebay). Personal preference I know, but I didn't like the boxy look of the MA Radius 225 on the wall when I saw some at a local Sevenoaks. This has then determined to some extent the remains of the setup. Either side, L&R, I'm going for some MA A10s (bought on here). Rears are still TBC - for now and for budget I was looking for some MA Radius 45s, but open to suggestions.
As you can see from the sketch below (attached?), I'll have about a foot either side of the TV (green box on the right hand side - 65" probably an LG G1 OLED) before narrow (50cm) windows and then another foot to the wall at either side. The wall behind the TV is 2.1m. So do I place the L & R channels at the location of the yellow triangles or blue triangles? I didn't think I'd get very good stereo imaging at the location of the yellow ones given the viewing distance so preferred blue locations - but acknowledge this is in the corner. Is this less of an issue with front ported A10s though? Corner (blue) would also probably work better for Mrs J (less obtrusive).
Rears, can be a bit more flexible, but would you suggest on the wall behind the listener (red), or at the back and to the side angled in (purple)? Again, there's about a foot on the returning wall.
In-ceilings - 2/3rds back from the screen I've been informed is pretty optimal. Open to recommendations as to the speakers themselves or alternate positioning.
Subwoofer - open to suggestions to location and the sub itself. Styling will also determine where it can go. I'd be happy going bottom right in the image. Mrs J may prefer to move the sofa away from the bifolds and tuck in the top left if it's not a looker.
AV receiver - I've not put much thought to yet but I do like the Denons and have been impressed ever since I had one of their stereo units years ago. I'm probably going to budget £600 for now and it may be reserved for an upgrade in the future.
For now, I just need to make sure I'm getting all the wiring concealed and to the right places! I'll worry about upgrades in the future.
Many thanks in advance. Please be gentle
