New epg not downloaded
adriandg
Established Member
I have a 1tb sky hd box in the living room and the new epg has downloaded to that. I have a second hd box in the bedroom which isn't a 1tb box but is only about a year old and the new epg hasn't downloaded to that. Can I force it to download or do I just wait until it does it itself?
nsewell
Established Member
As long as it's a DRX 890 or 895 then you can force update your box to it now.
It should be a 890 if it's about a year old and isn't 1 or 2tb.
razy60
Think yourself lucky, i have an old amstrad box and so far have had to hard reset it twice as the new epg messes up recordings, audio, channel changing and i have to press more buttons to get anywhere, And its just updated its self again tonite so i have lost 2 recordings and have no mini tv in epg etc. as apparently recordings (of which none are going on) have been interrupted due to signal loss (which is fine).
thanks sky:censored:
mark2160p
Anyway of getting the old EPG back the new one is absolutely shocking. The response time of pressing sky buttons is slow. If you press the backup button it goes back to the EPG, where you have to press the back up button another 3 times to get back to screen. Thanks sky! What a big steaming pile of sh*t
nsewell
Established Member
There's no way of getting the old EPG back.
Have you tried permanently deleting everything in the deleted folder then performing a planner rebuild.
You could also try a forced software update after that.
It can sometimes speed things up.
If you want to exit the Sky guide just press the Sky button instead of BackUp.
kez
This new 'feature' annoys the hell out of me
Will give this a try, assuming i can figure out which button i assigned to 'Sky' on my Harmony :(
logiciel
Maybe you didn't - same as me!
I may go back to the activity some time and customise it.
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
