new dvd r disc help please
Discussion in 'Computer Software & Operating Systems' started by pointyone, Dec 27, 2006.
  1. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    just got a new lite on dvd writer records to all formats including dual layer
    i want to back films up to disc console games etc etc
    so which a the best discs to use for each application ie films games +r -r +rw etc etc
    also whats the best type of discs to get and the best place to get them
    bit new to writer so a fools guide would help
    thanks for any help
  2. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    what writer is it ?
    Also check out SVP - they stock a good selection of media and report on how they fare on various writers. So you can get a good match-up.
    If you have a dvd-recorder under your telly you may want to opt for disc compatible with that so you can (record and) play on PC and DVD recorder box.
  3. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
  4. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Do you have - or are you planning to get - a DVD recorder to plug into your telly ?
    Do you want to print nice pictures on the top surface of the DVDs ?
  5. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Have a look at
    svpdotcodotuk/helpdesk/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=70
    (play the dot game with the URL)
    saves me some typing :)
  6. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    may get a dvd rec but not bothered about the disc label
  7. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    if your recorder (will) need -R disc then stick to them. if it needs +r discs then stick to them. Have not looked to see if your DVD drive supports DVD-RAM discs.
    Suggest you research recorders a little and see what likely format you will use on that box and then go for that format - but the last sentence in this post is very relevant to that decision.
    e,g my dvd recorder uses -R so I use a lot of those. but also can use double layer +R discs on PC so also use those. can also use DVD-RAM.
    there are more pages in the SVP knowledge base that will help with this.
    What formats does your drive support ?
  8. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    Okay - I cheated and looked. Looks like your drive supports many formats.
    wwwdotciaodotcodotuk/LiteOn_LH_18A1H__6576145#productdetail
    so you can pick what you like.
    Compatibility with any future DVD recorder the only factor.
    try the SVP sample packs for starters maybe.
    and pay attention to their ratings. DVD blanks like everything else cheaper is not always best..
    Also try dual layer as then you can make true fair use copies (with no extra compression) of your precious DVDs.
  9. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    yep it supports dvd ram(what are these used for)
    dual layer again ??????(what are they used for)
    i plan to backup up
    all my dvds..
    the files for some hi def movies
    may be some console games
    most mainly for storage i think i will go down the R- route
  10. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +199
    DVD RAM is a Panasonic format.
    Dual layer has twice the capacity of single layer. Commercial DVDs of films are on dual layer as they need the extra capacity.
    I think the svp pages describe these better than I can.
