Hi.
I currently project my ae300 image on to a lightish green wall with a Pioneer dv444 player through svideo.
I am happy with the picture quality and the green wall doesn't seem to make much of a difference to what I think the colour should be (the room is in complete darkness when viewing films). There's always room for improvement though so I was thinking of improving my system a bit.
Which do you think would be the best way to upgrade my system - a new prog scan dvd player (I was thinking of the Sony 730) or a proper screen (or at least a DIY one)? Simply painting a square on the wall icestorm 6 with a black border would be the easiest solution, but the missus is dead against that idea (typical!).
I recently tried the projector through vga from a laptop and was blown away by the difference so at the moment I am leaning towards a new DVD player (even though that will only do component there should be a marked improvement).
Thanks,
Taq
Thanks,
Taq
