New DVD Player - Cable/connection query
Discussion in 'Blu-ray & DVD Players & Recorders' started by MJeeves, Aug 30, 2001.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Dear All,
    I am purchasing a Toshiba SD900E DVD Player and wanted to get THE BEST cable to connect it to my Pioneer Rear-Projection T.V. Unfortunately, the Pioneer doesn't have Component Inputs, but it does have RGB Scart and S-Video. Which is the best connection I can possibly get? S-Video? RGB? Also which cables do you recommend? I have heard and read really good things about the IXOS 126AV 21 Pin Scart to Scart cable for RGB connection. Does anyone else use this?
    Please let me know as I really want to squeeze the very best out of my new player.
    Thanks.
  2. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    MJ<br />Cant vouch for svideo v RGB but FWIW I have the IXOS Scart you mentioned & it is superb - the plugs are so heavy they almost dont stay in the sockets ... Paul
