New DVD player and 5.1 advice
Discussion in 'Blu-ray & DVD Players & Recorders' started by Degas, Jan 25, 2005.
  1. Degas
    Degas
    Aug 29, 2004
    191
    Hello all, I have a range of equipment that I am pretty sure isn't set up to it's best connectivity (is that even a word?) and I need some advice on the best way to connect everything up, here's what I currently have:-
    42" Plasma JVC PD-42D30ES (http://www.jvc.co.uk/article.php?id=100154)
    Sky Digital+ (Just arrived )
    Panasonic DVD-RW DMR-E50
    JVC TH-V70R DVD and 5.1 surround sound system
    Now I am pretty sure I have got everything wired up individually correctly, it's just the order in which I connect them to each other I may have wrong. I would ideally like to record from SKY+ and then to my DVD-RW at as high quality as possible and also have a high quality output for SKY+ and my bought DVDs, I would also like 5.1 Digital sound for both DVD's and SKY.
    Now I want to keep most of my equipment but I am looking to replace the DVD player and 5.1 system with either a new system that can accommedate what I want to do OR use seperates. The problem being, the seperates will have to be thin to fit everything in, so I would need a 5.1 system and a seperate DVD player, preferably with component outputs so I can finally use that connection on my TV. (Divx compatibility would be nice)
    Sorry for the rant and if I have missed anything out, please ask.
    Cheers in advance, Simon.
  2. Degas
    Degas
    Aug 29, 2004
    191
    Bump, anyone..... :lease:
