New dvd drive would let me put xp on.
Discussion in 'Desktop & Laptop Computers Forum' started by bob1, Sep 16, 2007.
  1. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    I have changed most of my pc and i have fitted a sata dvd drive, i wanted to do a fresh install of xp pro but it would only go as far as the bit where it says "windows is checking hardware" and just stops. I eneded up connecting an ide drive just to get it installed.
    :lease:
    Thanks.
  2. Phil W
    Phil W
    Oct 6, 2005
    118
    Norwich
    +5
    whats the spec of the PC now (mainly m/b and ROM drive make/model)?
    Phil
  3. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    This is the pc spec.
    Msi K8MM3-V motherboard
    Sempron 64 3400+ cpu
    512mb ddr400
    ti4200 graphics card
    The dvd drive is an Lg GSA-H62NBAL ,it works fine other than the problem stated.
  4. JuzzyD
    JuzzyD
    Nov 18, 2004
    225
    28
    +24
    Have you checked in the BIOS to see if there's an IDE emulation mode for the SATA?
    Is the SATA setup for RAID in the BIOS?
  5. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    I set it to IDE , i was able to use a system eraser boot up disk no problem,it did read the windows disc but stopped at the point i said.
