New DTT card
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, Apr 25, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Just got an email from Maplins special offers and noticed this http://www.maplin.co.uk/default.asp?CartID=10747962&targetmodule=35353 AVerMedia DVB-T Digital Terrestrial Receiver PCI Card
    which was quite interesting, reduced to £80 at the minute and with a svideo in as well as the stuff the Nebula has.
    Anyone got one or want to be the guinea-pig?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I had one for a day, the software is very feature-less and can't even display a 16:9 picture at the correct aspect ratio - so you get tall and skinny-vision, took it back to maplin under their 14 day money back guarantee. I wouldn't buy one if I were you, but you could try one out :)
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Yous seem to be into all the DTT stuff;) Cheers for the reply but could you elaborate
    Did you try it on a 16:9 display or a 4:3 and so is it a problem caused from a :3 display that wouldn't exist with a 16:9?
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    On a 4:3 display the 16:9 picture was horizontally squashed, so if you did have an anamorphic display like plasma it would unstretch it to make it look right, but I dont think they had that in mind when they were designing the software!
