New Disk Sky+ Cable Snap - HELP!!!
Discussion in 'Sky Digital TV Forum' started by dgharwood, Dec 8, 2004.
  1. dgharwood
    dgharwood
    Apr 1, 2004
    88
    Swansea
    +6
    I have been following the instructions on www.hummer.co.uk to install a new hard drive. I was carefully (os so I thuoght) removing the cable from the hard drive and the cable came away from the connector in the drive.
    Is this a standard cable that I can get replaced - although it is quite short. Can anyone advise please I am now having a nightmare!
    Thanks in advance.
  2. dgharwood
    dgharwood
    Apr 1, 2004
    88
    Swansea
    +6
    I have jsut found my answer after trawling the web - spares are available from www.satcure.co.uk. Hope this helps someone too!
  3. DaveP
    DaveP
    In the short term (until your new cable arrives) you could use a standard cable.
    Dave
  4. dgharwood
    dgharwood
    Apr 1, 2004
    88
    Swansea
    +6
    Thanks - tried that today and it works - even managed to stuff it all into box -I will switch box off tonight as I am conerned about ventilation but it is a solution.
    I have felt like my right arm was severed without the ability to use SKY+ or in fact watch any TV last night :zonked:
