New digibox and letting sky know about it!
Discussion in 'Sky Digital TV Forum' started by baronT, Mar 15, 2005.
  1. baronT
    baronT
    I have SKY+ and a multiroom digibox installed at home.
    Just recently my multiroom digibox has gone a bit pear shaped and gives me a "no satellite signal being received" error message. Thinking it could be the line in rather than the box, I tried it out on the SKY+ feed but it still doesn't work. (SKY+ works fine).
    I rang SKY and as its not under warranty, they want a £65 call out charge.
    So, I was thinking its probably a better idea to go out and buy another digibox myself and keep sky out of it.
    Questions:
    1) Any recommendations on a box to purchase? and where to purchase it?
    2) Do I have to let sky know about the new box or do I just plug the card in a nd away I go?
    Thanks in advance for any help!!
  2. johndon
    johndon
    Feb 3, 2002
    1,989
    63
    +122
    If you get a new box, you have to ring Sky to get them to 'marry' the card to the box.
    John
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    If you are outside of the minimum term for the multiroom subscription then you might consider ringing SKY to cancel and when they ask why tell them the digibox doesn't work. They might offer a reduced call out or a free one, you lose nothing really if they don't since you are planning on buying a new digibox anyway.
  4. Boy Lex
    Boy Lex
    Have you tried a box reset? Press and hold backup on the box while plugging in the power cord - this should do a software update on the box too. Might just ressurect it.
