HouseofMu
Established Member
I've (like many others no doubt) been comparing the differences of the forthcoming Denon players (1910, 2910, 3910).
For me video quality is the priority, I'm not fussed about the DVD-A/SACD playback.
The video DACs in both the 3910 and 2910 are the same (Dual, Discrete 12-bit, 216MHz Analog Devices Video DACs) but the cheaper 1910 doesn't have these.
However, am I right in thinking, these higher grade video DACS only affect video output quality via Component connection and if I were to just use the DVI connection, they're not employed - making them redundant?
I see the DCDi FLI chips are also different, but I believe from a little research, the FLI2301 (in the 1910) is analogue+digital capable whereas the dearer FLI2310 is purely digital (hence the use of external DACs), again making the different versions irrelevant - unless the quality of the scaler is different?
So, in a nutshell, if connecting via DVI, the video quality should be exactly the same as either the 2910 and 3910 ???
neil.
neil.
