New Denon DVD players & PAL discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by leedsfireman, Dec 3, 2004.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Can anybody please confirm what the new players can & can't do regarding upscaling via the digital connections.i.e. pal & ntsc discs.
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    As confirmed on the other thread the 3910's deliver 480p/720p/1080i output via the HDMI/DVI & Component outputs for NTSC material and 576p/720p/1080i for PAL material
  3. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    OK thanks do you know about the 2 other models cause this is what i saw,
    Big_AL007
    Trader Rating: (2) You can not upscale the 2910 on PAL disks through DVI only on NTSC, this may make a big difference if your collectionis mainly NTSC. Not sure whether it works ok through HDMI, if anyone knows a way around this I would like to know.
    You can set it to out everything in NTSC but in my experience it seriously degrades the picture quatity.
    AL
    Purveyor of HiFi, AV & Projector screens Draper and Others.
    al@ams-computers.co.uk
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Well, I installed a 2910 yesterday married to a Pioneer 435XDE connected via HDMI. Played Spidernan R2 and set player to 720p. Screen reported signal as 750p and image looked perfect to me (and the client).
  5. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    1910 can upscale both PAL and NTSC discs to 720p/1080i.
    There is a problem with PAL upscaling on some displays where the image does not fill the screen - for example I have a 1910 and Sanyo PLV-Z2 projector and get a gray broder around the image when upscaling. There is a fix for 1080i with this display but not 720p.
    Of course the 1910 only has DVI.
  6. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Does the 1910 offer a good picture improvement when upscaling compared to your old player, i'm just trying to get all the facts correct before i decide which one to go for.
    Thanks.
  7. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Isn't it against DVD licensing rules that it allows upscaling via component? I wouldn't have thought a company as big as Denon would do that.
    Steve
  8. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    i dont think component does upscale.
  9. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    My "old" player was an Xbox (!) - albit using the official MS hidef pack through a component connection.
    I can't see THAT much improvment to be honest. It's better, but not by a great deal. Both give a great picture. The Denon seems better when upscaling to 720p (not surprising as it's the native resolution of my display) vs 1080i, but it doesn't fill the screen on PAL discs.
    The main reason I bought the 1910 was for the upscaling, but also so I didn't have the Xbox cable trailing across my cinema.
  10. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    WEll, I don't use component so may be wrong but the player certainly gives you the option to choose 480p/576p, 720p or 1080i when HDMI & DVI are OFF.
  11. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Forget the 1910, really tinny unit. I auditioned the 1910/2910/3910 yesterday and ended up upgrading from the 1910 to the 2910.
  12. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    +3
    The 2910 does this for 480/576p but is ok in 720p and 1080i mode - just set it to 720p and you'll get a better picture anyway.
  13. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    +3
    It upscales both NTSC and PAL via HDMI/DVI - just tried it down here R4 PAL and R1 NTSC - pj reports 720p on both disks
  14. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    +3
    The 2910 does not upscale via Component, only HDMI/DVI
  15. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    The manual for the 3910 states that for 1080i NTSC should be selected(rather than Auto or PAL), doesn´t that mean that it forces PAL to 60hz, atleast with 1080i?
  16. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    probaly, but theres no real benefit from choosing 1080i over 720p anyway. the 1080i setting seems to work fine when machine is set in auto mode
  17. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    For my 5700 the 1080i doesn´t work, it gives an unstable vibrating image. Haven´t tried switching to NTSC though.
    "probaly, but theres no real benefit from choosing 1080i over 720p anyway."
    There´s a thread over at avs and I think many prefer 1080i for 720p displays oddly enough. But surely 1080i might look better on a 1080p display?
