New Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by pavlos, Jun 20, 2001.
Tags:
  1. pavlos
    pavlos
    Mar 5, 2001
    11
    I was told by a friend of mine in Germany that last week was announced that the replacement of the 3801 will be the 3802 and will include the Pro-logic 2 format, availabilty expected in UK end of November 2001. Any feedback will be appreciated..
    Thanks in Advance
    Pavlos
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
  3. samhassall
    samhassall
    Does this mean that a 2802 will be coming out in November aswell? I wonder if this will have DPLII aswell? It should have if Onkyo have a £450 DPLII receiver out already. I was considering this model, but the only pre-out that it has is for a subwoofer, making upgrades in the future very difficult. Anyone have any ideas on other receivers I should consider, or should I wait for the new breed of models to come out later this year? My budget is £500.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Yamaha will come out with some new models soon, too. If there is no hurry wait a while and then compare them to each other and buy the best you can afford ...
