New demo channel from Canal+ France on Astra
Discussion in 'General TV Discussions Forum' started by Eson, Jun 10, 2005.
  1. Eson
    Eson
    Jul 4, 2003
    34
    New demo channel from Canal+ France on Astra.
    Sat: Astra 19.2° E
    Freq: 12582 V
    SR: 22000
    VPID: 165
    APID: 100
    ServicePID: 9306
    Some real eyecandy on there, 1080i@14,5mb
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,258
    Manchester
    +753
    Quite good - and within a mux as well.
    Pity they have to use that 'orrible shutttering effect as a link between clips.
    (and all sound in French)
    FEC is 5/6.
    TSReader currently reports 14 Mbps.
    Convenient timing 'cos I already had dish at 19E doing some tests on the Premiere H264 stream on the same bird (had an email from Rod, TSR author, asking me to do some tests with new beta version just completed)
    For ayone with the registered version of TSReader with access to new betas, there are quite a few improvements in version 2.6.42 ; Rod was was explaining some of them last night in the USA Satforums chatroom.
    For starters tone or voltage controlled band switching of LNBs is now supported automagically (once you tell it your type of LNB).
    Chris Muriel, Manchester.
  3. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    The channel is viewable with the VLC player via TSreader 2.6.41 but not very good. Any setting I need to adjust as Prog DVB etc playback is 100%
