New DAP! iPod MP4 Player
Discussion in 'Headphones, Earphones & Portable Music' started by ipodstudio, Jun 21, 2005.
Tags:
  1. ipodstudio
    ipodstudio
    LOL! They're at it again! Here comes another iPod ripoff! THIS ONE is even called the "iPod MP4 Player"... :rolleyes:
  2. gerbilly
    gerbilly
    Mar 20, 2005
    2,182
    Hamilton
    +94
    Looks quite nice if you ask me, all depends on price and how it sounds and of course the software.
  3. ipodstudio
    ipodstudio
    Yep. I love the way companies get themselves noticed by blatently ripping off Apple and then waiting for it to hit the fan... :D
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    I'm with Gerbilly on this one! Looks nice to me! And look at the specs:
    :smashin:
  5. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Ipod MP4 player(20G)
    Built-in Storage : 1.8'' 20GB Hard Disk, Up to 4 Primary Partitions
    Memory Card : 3 Slots, 7 Card Types: CF/MicroDrive, SD/MMC/MS, SM/XD
    File Management : Full Card Backup / Photo Backup to HDD, Copy Speed Select; Single File / Folder Copy & Paste between any Storage Media. File Deletion, Hard Disk Format
    Connected to PC : As External HDD + Multi-Card Reader
    File System : FAT12/16/32
    Operating System : Windows 98/ 98 SE/ME/2000/XP; Linux Kernel Version 2.4 and Later; Mac OS 8.6 and Later
    Key Definition : Up, Down, Left, Right, Power, ESC, Menu, +, -, Select and Reset. Key Lock by Software
    Language : Multi-Language OSD Menu and Filename Display
    File View Mode : Icon or List View
    AC Adapter : DC 5.0V, 2A
    Battery : Rechargeable, User-Replaceable Li-Ion 3.7V/1800mAh
    Maximum Playback Time :
    Video: 3.5 hours, Audio: 7.5 hours
    Power Saving Features : Auto Power Off, Screen Saver, Hard Disk Spin Down
    Display : 2.0'' LTPS TFT LCD, 558x234 Pixels, Backlight Adjustable
    TV-Out NTSC/PAL
    No. Channels : Stereo (L+R)
    Line Out : 2 Audio Jacks: Dual Earphone Support
    Remote Control : Infrared
    Firmware Update : DSP Firmware by Direct File Execution, USB Firmware by PC
    PC Connection : USB 2.0, Maximum 480Mbps
    Dimensions : 128x69x24mm
    Box dimensions : 240x158x67mm
    Carton dimensions : 490x326x350mm ; 20Pcs/Carton
    Weight : 245g (including HDD and battery)
    Operational Temperature : 0º to 40º C
    Supported File Types and Playback Functions :
    1) Image:
    JPEG (*.JPG) : Baseline YUV and Grayscale (No Progressive), Up to 16M Pixels;
    TIFF (*.TIF) : 1 and 8-bit Grayscale, 8-bit Indexed-Color, 8 and 16-bit True Color;
    BMP (*.BMP) : Monochrome, 8-bit Indexed-Color, RGB, RLE8
    RAW (*.NEF, *.ORF, *.CRW,*.RAF, *.OCR) : Support Following Camera Models: Canon: 1Ds Mark-II, 1Ds, 1D-II, 1D, 20D, 10D, 300D (Digital Rebel, Kiss Digital), D30, Power Shot G2
    Nikon: D100, D70, D1X, D1
    Fujifilm: S2 Pro; Olympus: E-1
    Kodak: DSC Pro SLR/c, DSC Pro SLR/n, DSC Pro 14n;
    Motion JPEG (*.AVI, *.MOV) : 320x240 at 30 fps, Audio: ADPCM
    MPEG-1 (*.MPG, *.DAT) : 352x240 at 30 fps, Bitrate: 1.5Mbps, Audio: MPEG-1 Layer II/III, Remark: VCD
    ISO MPEG-4 (*.MP4) 720x480 at 25 fps / 640x480 at 30 fps, Bitrate: 4Mbps, Audio: AAC, Remark: Simple Profile without 4MV;
    DivX 5.x (*.AVI) : 720x480 at 25 fps / 640x480 at 30 fps, Bitrate: 4Mbps, Audio: MPEG-1 Layer III, AAC, ADPCM;
    MP3 (*.MP3) : MPEG-1 Layer I/II/III, Sample Rate up to 48KHz, Bitrate: 16~384Kbps, CBR & VBR, Stereo or Mono;
    WMA (*.WMA) : WMA 7/8/9, Sample Rate up to 44KHz, Bitrate: 32~192Kbps, CBR, Stereo or Mono
    AAC (*.M4A, *.AAC) : MPEG4-AAC, Sample Rate up to 48KHz, Bitrate: 16~320Kbps, CBR, VBR & ABR, Stereo or Mono;
    WAV (*.WAV) : Sample Rate up to 48KHz, Stereo or Mono, Uncompressed 8 or 16-bit PCM in MS-RIFF WAV Format;
    CDA : CD-Audio, 18-bit 44.1KHz Stereo.
    Function
    Preview (Embedded Thumbnail Only)
    Zoom In / Out
    Rotate & Shift
    EXIF Display
    Slideshow with Music
    Set as Background
    Volume Up / Down
    Left-Right Channel Selection
    Fast Forward / Rewind
    Volume Up / Down
    Playlist Manager
    Shuffle, Repeat
    7 Preset EQ
    Hide as Background Music
    ID3 Tag Support
    Looks a half decent spec to me :thumbsup:
  6. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    The only problem I can see is the battery life:
    :eek: :thumbsdow
  7. kevH
    kevH
    Oct 11, 2004
    833
    +37
    The battery is user replaced , im sure a better battery could be found.
    cant seem to find where its available or price
  8. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    I doubt it, it is the unit itself which drains power not the fact the battery is crap (which Im sure its not).
  9. ipodstudio
    ipodstudio
    LOL! The specs are fine, it's more the name and design that are bothersome.. :D
