New Crayston HTPC good value??
Discussion in 'Desktop & Laptop Computers Forum' started by salty5000, Aug 12, 2002.
  1. salty5000
    salty5000
    I didnt get much of a response at the end of the old thread so I thought id ask the same question again.......
    Does anyone have anything to say about the new version of this HTPC??? Its cheaper at £649 which seems like better value if it will save me making my own machine .....
  2. jrwood
    jrwood
    The reason why its cheaper is because its using some custom chip which probably has the performance of a celeron 500mhz ...
    If your not comfortable making your own PC for next to nothing then maybe a friend could build it for you?. I know some PC shops also build computers from PC parts.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    ....if you've never built a machine before, and need help, I took a load of pics as I was building my HCPC, which I'll try and get on line soon with comments - it won't be an exhaustive guide, but it might give you a bit of confidence....
